BL-Touch to Alfawise U10
@phaedrux
No light. I´ll check the wires. -
@pertti The BL touch wire connector was 1 step aside in the motherboard.
I´ll continue the experiment soon. -
@pertti Now it gets power! At the start the Bl-touch moves back and forth . After homing it twinkles red light.
I have no idea weather the BL-touch is supposed to be the z-endstop or not. Is my configuration ok? -
@pertti do M401 and M402 work to deploy and retract the probe?
@pertti Do you have a Z stop switch as well as the BLTouch? If not and you want to use the BL for Z homing, you'll want to change M574 Y1 S1 P"ystop" to M574 Z1 S2 in your config and define a Z homing macro.
This blog post here give an excellent overview of the macros:
https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/
Remove the M280 command in the config, that belongs in the Pin Down macro.
@lo-fi Yes I have a remainig z endstop. I do not know is it worth saving. Less moving parts sounds good. And if I changed the bed surface thickness then it is easier to handle with z probe.
Share your homeall and homez here and we can tell you if anything needs to change. In general though, to home Z with the probe you need a G30 command. And before the G30 you'd need a G1 X Y command to move the probe into position. Ideally the center of the bed.
@phaedrux
I´ll check this, looks good. https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sun Mar 06 2022 15:03:52 GMT+0200 (Itä-Euroopan normaaliaika)
G91 ; relative positioning
G1 H1 X-405 Y-405 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-405 Y-405 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-505 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika)
G1 H1 Z-505 F1800 ; move Z down until the endstop is triggered
;G90 ; absolute positioning -
@pertti said in BL-Touch to Alfawise U10:
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)Remove those lines in homeall and replace them with
G90 G1 X150 Y150 G30
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)And in homez, remove those lines and replace them with the same.
@phaedrux
Thank You all! First testprints going on! So far so good. I removed the z endstop and replaced it with z-probe. -
