Motor stuck when setting steps per mm
@engikeneer Sigh..., so it's back to a speed issue.
@jay_s_uk said in Motor stuck when setting steps per mm:
@e4d sounds like you're trying to move your motors too fast for the steps per mm you need. try a slower move
That solve my problem, thank you. I must be quite slow (max 2000 mm/mn), it may be due to the mechanical design
@e4d said in Motor stuck when setting steps per mm:
I suggest you use the motor EMF calculator to estimate the maximum speed.
You can find the EMF calculator here: https://www.reprapfirmware.org/
And a steps per mm calculator here: https://docs.google.com/spreadsheets/d/1ts5fz73JQoQ4G0Z95nzfPDSS6HYEyczyZyccDZ5M6B4/edit#gid=0
I put the correct steps per mm in my config.g (1275) and I can only have really slow speed (max 700 mm/mn, 12 mm/s). I don't really understand why I can't go further. This is a really low speed.
I tried calculating with EMF Calculator, you can find my calculation here. I understand I may not be able to go to 150mm/s but 40-50mm/s should be doable. What am I missing here ?
@e4d next two things are acceleration and friction.
Ball screws typically have quite high interia and so a whole bunch of the motors power is used just accelerating. Plus you also have the mass of the gantry/head to accelerate. What acceleration (and jerk/instantaneous speed changes) do you have in your config? Maybe try dropping them a bit.Any friction in your system will also take power from your motors and limit your top speed. Make sure everything is well aligned and properly lubricated/greased. It should all rotate freely by hand when powered down.
Another thing to try is to reduce your motor current. That will increase your max speed the calculator gives! Also if you're running at 1500mA on a 1600mA motor, they may get quite hot which might make them less efficient (though I'm not so sure on that one)
Plan B is to get some 1.8deg motors as you'll be able to run them twice as fast for the same parameters
@engikeneer yes, 0.9deg motors make no sense when the steps/mm is so high.
@engikeneer Here's my config on this part :
; DRIVES CONFIG M584 X0.0 Y0.1 Z0.2 A0.3 C0.4 E0.5 ; set drive mapping M92 X1275.00 Y1275.00 Z1275.00 A367 E420.00 ; Set steps per mm assuming x16 microstepping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M566 X400.00 Y400.00 Z8.00 E2.00 ; set maximum instantaneous speed changes (mm/min) M203 X35000.00 Y35000.00 Z5000.00 A5000.00 C5000.00 E1200.00 ; set maximum speeds (mm/min) M201 X6000.00 Y6000.00 Z1600.00 A2000 C2000 E250.00 ; set accelerations (mm/s^2) M906 X1600 Y1500 Z1500 A600 C600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M906 E1000 I10 ; Idle extruder motors to 10% M84 S30 ; Set idle timeout
I can rotate the system when powered down. I will look into 1.8 deg motors.
@e4d if you want to stick with these motors, definitely reduce acceleration (M201). Try 10x less for starters.
Your instantaneous speed change (M566) is reasonable, but I'd also try dropping that too.
