Duet 3 demo at TCT
@phaedrux said in Duet 3 demo at TCT:
Currently the DWC runs on the same CPU on the Duet that also handles everything else the printer has to control. It used to run on the even slower wifi chip.
Duet 2 = 120MHz 32-bit, ESP8266 = 160 MHz 32-bit.
I think moving the web task to the main Duet 2 chip was because there is no ESP8266 in Duet 2 Ethernet.
And in terms of performance, that is a mistake, because the main chip has realtime tasks to do while ESP8266 is mostly idle now. -
No, the main reason we moved the web server to the main processor is because it was too hard to debug the web server on the ESP, and because of the closed source SDK for the ESP we could never be sure whether CPU time used by the web server was impacting on the WiFi performance. Also it was taking too long to upload DWC to the ESP during manufacturing.
Like most users, we run the ESP at 80MHz, not 160MHz.
Sounds really exciting. Do you have a timeline for when beta or first retail will be available?
I would like to be on the list of Beta Testers if it is possible -
@percar we want to have some initial production boards in Q2 2019.
modern Linux operating system
You have a great sense of humor!
The new design looks very well thought out.
It's a good thing it is not going to be around until next year - gives me time to come up with the reason why I have to have it - it's a "wife" thing.
@t3p3tony Hey, so how close are you guys to that Q2 2019 goal for early production boards?
Can you take my money for it yet?
Would it be possible to make an expansion board that mounts directly to the extruder? Say it has a single stepper driver, some PWN fan controls, Z probe input, heater control and a thermistor input? Would be really nice if all you had to run to the extruder is power and data, instead of having a mess of wires like normal. Would also make tool changing much easier.
@surgikill said in Duet 3 demo at TCT:
I think they've actually talked about a board exactly like that.
It will be a smart tool board, handling at least an extruder motor, heater, temperature sensor, 2 fans and a Z probe.
I do have a Duet 2 - I don't need a Duet 3 - I do have a Duet 2 - I don't need a Duet 3...
Just practicing. I need to get this mandra working until Duet 3 is available.
I was testing the Duet 3 second prototypes earlier today.
@wilriker said in Duet 3 demo at TCT:
"This Is Not the Duet You Are Looking For"
@dc42 said in Duet 3 demo at TCT:
what are the main cool features, compared to DuetWiFi ? will you uncover a bit?
this link www.duet3d.com/duet3 does not work
@c310 That link works for me.
Manuel, - it's "mantra" not "mandra" (that's a town in Greece). Oh and it's "practising" not "practicing".
Here endeth the English lesson for today
@deckingman Yeah, the mandra-mantra thing is the same in German.
But with "practicing" I can - for once - correct you.
This is the valid American spelling. And since I usually also write "color" and "honor" I consider this correct.
@wilriker I gave you an English lesson, not an American lesson.
They drive on the wrong side of the road and use all the wrong words for parts of cars (trunk instead of boot, hood instead of bonnet etc).
@deckingman; but at least they don't call a damper a shock absorber, which technically is the spring!
Edit: Conversations that are not intended as formal publications (particularly online) being pulled off track into irrelevant discussions in grammer, spelling, or other language technicalities is a pet hate of mine.
By all means raise questions when the use of language has left the message unclear but otherwise it serves little purpose.
@doctrucker Fair comment - and apologies. (Although sometimes a little light relief can be welcome).
