Multiple motion system
@Alva my best guess is that the move G1 X0 Y0 U0 in mini(1).gcode hasn't completed when daemon.g starts commanding U axis motion. This shouldn't be possible, because if U hasn't finished moving then U should still be owned by MS0, so the attempt to move it in daemon.g should fail with the "axis already owned by another MS" message. I'll check the M400 code.
@dc42 I have edited the code and logic a bit. Found different cases:
; File Name: /sys/daemon.g if(!exists(global.daemonStop)) global daemonStop = false ; Set to 1 to stop the daemon.g, it can be use to upload a new daemon.g file while( global.daemonStop == false ) if(state.status== "processing") G91 M596 P1 G1 U5 F300 M596 G4 P0 M99; Exit
test_2nd_MS.gcode
This happened when i activated the daemon before the move to X0 Y0. But if i activate the daemon after that then it works perfectly. Cannot relate whats going on.set global.daemonStop = true ; stopped the daemon M118 S{"starting to move"} G90 G1 X0 Y0 M400 S1 G91 set global.daemonStop = false ; activated the daemon which only use U axis G1 X100 Y100 F200 M400 S1 G90 M118 S{"move done"} M99
@Alva Looks like it is a timing problem or something.
@Alva thanks, I will try to replicate it.
@dc42 Thank you
@Alva I have reproduced this and I am looking into it.
@Alva I created https://github.com/Duet3D/RepRapFirmware/issues/1064 and I am testing a fix.
@Alva please try the new Duet 3 Mini firmware binary at https://www.dropbox.com/scl/fo/pasag1g18orahwvn49qp2/ABWgw6D-TyKWxxurTmGwiUE?rlkey=r9h3rjyw1l4wh7xbr8yho37gw&dl=0.
@dc42 It seems to be working. I have tried all the above conditions and works as intended. Can i expect the same fix for Duet3 6HC board as well, as i observed the same behavior in it as well. Thank you
@Alva I have just put a 6HC build at the same location.
@dc42 Thank you , I will check it out
@Alva please can you confirm if you have tested this.
@T3P3Tony Hello sorry, i haven't checked it out. The 6HC board i have is bit different from the original version. So i need to build it differently. I am actually waiting for the beta 3 version of the firmware now.
@Alva you could try 3.6.0-beta.2+5 at https://www.dropbox.com/scl/fo/1l1t3h52jkapaszdpcruz/AOWakD9qTwZ2HRnV7N3vVvQ?rlkey=42ehcpbas7rwgz6z1318mbceh&dl=0 if you like. Use it with care because the changes in it are quite substantial. You may wish to reduce motors currents until you are happy that it behaves correctly. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta3-in-preparation for important changes.
@dc42 Thank you. I will try it out and let you know the status.
@dc42 g binary "0:/firmware/Duet3_SDiap32_MB6HC.bin" not found , in the drop box this file is not available
@Alva Get the "Duet3_SDiap32_MB6HC.bin" file individually from here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.1
Otherwise it's in the zip file download in most releases, eg in "Duet2and3Firmware-3.5.4.zip" here https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4Ian
@droftarts thank you. got it.
@Alva Tested the second motion system with the new version 3.6.0.beta2 + 5, but i am getting the error shows in the picture below:
tried gcode :
set global.daemonStop = true ; stopped the daemon M118 S{"starting to move"} G90 set global.daemonStop = false ; activated the daemon which only use U axis G1 X0 Y0 M400 S1 G91 G1 X100 Y100 F200 M400 S1 G90 M118 S{"move done"} M99
daemon.g :
; File Name: /sys/daemon.g if(!exists(global.daemonStop)) global daemonStop = false ; Set to 1 to stop the daemon.g, it can be use to upload a new daemon.g file while( global.daemonStop == false ) if(state.status== "processing") G91 M596 P1 G1 U5 F300 M596 G4 P0 M99; Exit; File Name: /sys/daemon.g
