Multiple motion system
@dc42 It seems to be working. I have tried all the above conditions and works as intended. Can i expect the same fix for Duet3 6HC board as well, as i observed the same behavior in it as well. Thank you
@Alva I have just put a 6HC build at the same location.
@dc42 Thank you , I will check it out
@Alva please can you confirm if you have tested this.
@T3P3Tony Hello sorry, i haven't checked it out. The 6HC board i have is bit different from the original version. So i need to build it differently. I am actually waiting for the beta 3 version of the firmware now.
@Alva you could try 3.6.0-beta.2+5 at https://www.dropbox.com/scl/fo/1l1t3h52jkapaszdpcruz/AOWakD9qTwZ2HRnV7N3vVvQ?rlkey=42ehcpbas7rwgz6z1318mbceh&dl=0 if you like. Use it with care because the changes in it are quite substantial. You may wish to reduce motors currents until you are happy that it behaves correctly. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-Beta#reprapfirmware-360-beta3-in-preparation for important changes.
@dc42 Thank you. I will try it out and let you know the status.
@dc42 g binary "0:/firmware/Duet3_SDiap32_MB6HC.bin" not found , in the drop box this file is not available
@Alva Get the "Duet3_SDiap32_MB6HC.bin" file individually from here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.1
Otherwise it's in the zip file download in most releases, eg in "Duet2and3Firmware-3.5.4.zip" here https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4Ian
@droftarts thank you. got it.
@Alva Tested the second motion system with the new version 3.6.0.beta2 + 5, but i am getting the error shows in the picture below:
tried gcode :
set global.daemonStop = true ; stopped the daemon M118 S{"starting to move"} G90 set global.daemonStop = false ; activated the daemon which only use U axis G1 X0 Y0 M400 S1 G91 G1 X100 Y100 F200 M400 S1 G90 M118 S{"move done"} M99
daemon.g :
; File Name: /sys/daemon.g if(!exists(global.daemonStop)) global daemonStop = false ; Set to 1 to stop the daemon.g, it can be use to upload a new daemon.g file while( global.daemonStop == false ) if(state.status== "processing") G91 M596 P1 G1 U5 F300 M596 G4 P0 M99; Exit; File Name: /sys/daemon.g
@Alva U axis was trying to use only in the second motion system. so motion system 0 and motion system 1 are not able to execute simultaneously.
@Alva i have tried the same with the 3.6.0.beta2 +3 it worked as intended
@Alva We're going to release 3.6.0-beta.3 in a couple of days, please retest when we release that.
@droftarts Sure will do. Thank you.
@Alva it's released:
https://forum.duet3d.com/topic/37289/software-version-3-6-0-beta-3-now-available
Testing is appreciated
My understanding of the dual gcode stream is: you can open two gcode files at the same time and have a daemon.g running in the background?
At the same time you'd have to split the config.g into two portions.
Maybe put the U-axis specific lines in the startcode of the second stream? -
@T3P3Tony Tested the above mentioned testing procedure and got the same error as 3.6.0.beta2 + 5.
@o_lampe So my requirement is to use the unused axes during printing. so the movement of the unused axes is set in the daemon.g. It is trigerred by a flag. My understanding about multiple motion system is the unused axes should be accessible by the other motion system. The error i am getting is that somehow the unused axis is also used by the print job motion system.
