duex5 setup
Here the firmware says its for a duex2 after updating using the DWC firmware upload tool
Sorry its this one @Phaedrux
@rister502dad ```
m122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet Ethernet 1.02 or later + DueX2v0.11
Board ID: 0JD2M-9F8TA-GJ4TN-6JKDD-3SJ6S-1RU24
Used output buffers: 6 of 26 (21 max)
Static ram: 23836
Dynamic ram: 70844 of which 40 recycled
Never used RAM 17360, free system stack 206 words
Tasks: NETWORK(ready,1511.8%,235) HEAT(notifyWait,7.2%,344) Move(notifyWait,1.1%,363) DUEX(notifyWait,0.0%,24) MAIN(running,8228.0%,464) IDLE(ready,0.0%,30), total 9748.0%
Owned mutexes:
Last reset 11:34:53 ago, cause: power up
Last software reset at 2023-05-31 18:37, reason: User, GCodes spinning, available RAM 17360, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Step timer max interval 0
MCU temperature: min 20.2, current 22.2, max 24.0
Supply voltage: min 0.5, current 0.6, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Events: 0 queued, 0 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5: ok, SG min n/a
Driver 6: ok, SG min n/a
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2023-06-01 17:24:02
Slowest loop: 4.65ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.1ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== DueX ===
Read count 0, 0.00 reads/min
=== Network ===
Slowest loop: 6.22ms; fastest: 0.05ms
Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
Interface state active, link 100Mbps full duplex -
@rister502dad said in duex5 setup:
Well it's not a firmware issue, but there may be something wrong with your Duex causing it to report as a Duex 2.
Can you please try reseating the ribbon cable to the Duex?
When and where did you purchase the Duex?
@rister502dad current production (version 0.11) DueX5 boards have a jumper that put them into DueX2 mode. It's at the top left corner of the witing diagram at https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#wiring-diagram. So if your DueX is version 0.11, make sure that jumper is fitted. There's another diagram showing it at https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#duex5-v011-with-external-drivers.
@dc42 Thanks for the suggestion I removed the jumper and tried again to install the firmware but it didn't work as well.
@rister502dad
Hi Phaedrux
I got this board from Filastruder on May 15th order 92688This board has actually never worked for me, the heaters work but not the steppers. I have had issues with the heaters in the past too and have wondered if there is something up with this board but then again there is a lot to understand about how the Duet works and those issues were resolved by messing around with the config file.
So the jumper was already present before? It should be installed to show as a Duex5, not removed.
@Phaedrux I didn't know about this jumper until today when I was advised to remove it. Either way I still am stuck having tried both ways.
@rister502dad I didn't advise you to remove the jumper, I advised you to check that it was fitted.
Understood. Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
@rister502dad ok sorry for the misunderstanding does seem to make sense to not mess with it to begin with
@rister502dad Cool thanks for the support.
