Optical Endstops
This post is deleted! -
@Adamfilip it is the resistor marked 181 that is too high a value for 3.3V. The good news is that you don't need to remove it (which is tricky), you can solder a 180 or 220 ohm resistor of the same size (probably 0603) on top of it, so that the two resistors are in parallel and make about 100 ohms.
Alternatively, if your Duet 2 is a sufficiently recent version, you can provide 5V power to those endstops as explained in the link that I posted.
5V endstops sometimes do work on 3.3V, so it's worth using M119 or the Object Model Viewer in DWC to test whether they are working.
@Herve_Smith 6 for $13 in US or 1 for $28 in Canada lol
@dc42 So if i manage to solder on a 220ohm resister like this. it should work.
@dc42 I can pickup some of these. but cant tell if they will work 3.3
https://wanhao.store/products/wanhao-duplicator-d7-end-stop-switch-v1-2
@Adamfilip said in Optical Endstops:
Error: Unknown pin name 'e6stop'
Where is it actually connected?
@Phaedrux duex5 e6stop
Change your pin name to
duex.e6stop
https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
@Phaedrux Amazing thank you! that fixed it all. its all homing properly now. im shocked to be honest.
I am curious why you need to add duex before e6stop but not when declaring the drive number on duex with M584
undefined Phaedrux marked this topic as a question
undefined Phaedrux marked this topic as a regular topic
@Adamfilip I use endstops that have an LM393 comparator chip and LED on board with Duet2 controller. They are very reliable and precise, except that I have had problems with them when sunlight hits them directly (an easy problem to fix, once you have figured out that that's the problem).
These are the exact ones I used, but they are no longer available.
These are similar to the ones I used.
The comparator slams the output either hard high or hard low, and it works fine with the voltage available at the pins on the controller board.
https://drmrehorst.blogspot.com/2020/01/ummd-gets-opto-endstops.html
https://drmrehorst.blogspot.com/2020/03/testing-ummds-xy-optical-endstops.html
@Herve_Smith I didn't LOL at you. more at the absurdity at the amounts Canadians get charged for things. Sorry Didn't intend any offense. unfortunately the same items in canada are priced very high, so the links you provided isn't a affordable option for me.. But I do appreciate you posting it as it helps to search for local alternatives.
wouldn't it work to just run the sensor from any spare 5V pin on the baord?
undefined Phaedrux has marked this topic as solved
@Nordle said in Optical Endstops:
Yes, I said that in my reply at https://forum.duet3d.com/post/305741.
