Optical Endstops
@Phaedrux M122
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5 Board ID: 08DLM-996RU-N85T0-6JKF2-3SJ6Q-1AVVR Used output buffers: 1 of 26 (26 max) === RTOS === Static ram: 23836 Dynamic ram: 75956 of which 40 recycled Never used RAM 11984, free system stack 134 words Tasks: NETWORK(ready,4.7%,242) HEAT(notifyWait,0.5%,333) Move(notifyWait,0.0%,282) DUEX(notifyWait,0.0%,24) MAIN(running,94.5%,442) IDLE(ready,0.3%,30), total 100.0% Owned mutexes: === Platform === Last reset 16:24:31 ago, cause: software Last software reset at 2023-01-19 16:51, reason: User, GCodes spinning, available RAM 12384, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Step timer max interval 0 MCU temperature: min 33.3, current 33.9, max 35.4 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: standstill, SG min 0 Driver 6: standstill, SG min 0 Driver 7: standstill, SG min 0 Driver 8: standstill, SG min 0 Driver 9: standstill, SG min n/a Driver 10: Driver 11: Date/time: 2023-01-20 09:16:09 Cache data hit count 4294967295 Slowest loop: 291.81ms; fastest: 0.18ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 26.8ms, write time 3.4ms, max retries 0 === Move === DMs created 83, segments created 11, maxWait 1260235ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 23, completed 23, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 18], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === DueX === Read count 23, 0.02 reads/min === Network === Slowest loop: 30.97ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 2 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address 84:0d:8e:b2:f8:6f WiFi Vcc 3.31, reset reason Turned on by main processor WiFi flash size 4194304, free heap 18176 WiFi IP address 192.168.0.183 WiFi signal strength -33dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
M98
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled FTP is enabled on port 21 Error: Unknown pin name 'e6stop' Extruder 0 has no filament sensor Endstop configuration: X: high end switch connected to pin xstop Y: none Z: noneError: in file macro line 111: M581: missing parameter 'T' Error: Accelerometer not found on specified port
This post is deleted! -
@Adamfilip it is the resistor marked 181 that is too high a value for 3.3V. The good news is that you don't need to remove it (which is tricky), you can solder a 180 or 220 ohm resistor of the same size (probably 0603) on top of it, so that the two resistors are in parallel and make about 100 ohms.
Alternatively, if your Duet 2 is a sufficiently recent version, you can provide 5V power to those endstops as explained in the link that I posted.
5V endstops sometimes do work on 3.3V, so it's worth using M119 or the Object Model Viewer in DWC to test whether they are working.
@Herve_Smith 6 for $13 in US or 1 for $28 in Canada lol
@dc42 So if i manage to solder on a 220ohm resister like this. it should work.
@dc42 I can pickup some of these. but cant tell if they will work 3.3
https://wanhao.store/products/wanhao-duplicator-d7-end-stop-switch-v1-2
@Adamfilip said in Optical Endstops:
Where is it actually connected?
@Phaedrux duex5 e6stop
Change your pin name to
duex.e6stop
https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#pin-names
@Phaedrux Amazing thank you! that fixed it all. its all homing properly now. im shocked to be honest.
I am curious why you need to add duex before e6stop but not when declaring the drive number on duex with M584
undefined Phaedrux marked this topic as a question
undefined Phaedrux marked this topic as a regular topic
@Adamfilip I use endstops that have an LM393 comparator chip and LED on board with Duet2 controller. They are very reliable and precise, except that I have had problems with them when sunlight hits them directly (an easy problem to fix, once you have figured out that that's the problem).
These are the exact ones I used, but they are no longer available.
These are similar to the ones I used.
The comparator slams the output either hard high or hard low, and it works fine with the voltage available at the pins on the controller board.
https://drmrehorst.blogspot.com/2020/01/ummd-gets-opto-endstops.html
https://drmrehorst.blogspot.com/2020/03/testing-ummds-xy-optical-endstops.html
@Herve_Smith I didn't LOL at you. more at the absurdity at the amounts Canadians get charged for things. Sorry Didn't intend any offense. unfortunately the same items in canada are priced very high, so the links you provided isn't a affordable option for me.. But I do appreciate you posting it as it helps to search for local alternatives.
wouldn't it work to just run the sensor from any spare 5V pin on the baord?
undefined Phaedrux has marked this topic as solved
@Nordle said in Optical Endstops:
Yes, I said that in my reply at https://forum.duet3d.com/post/305741.
