RRF 3.4.0beta7+5 SBC Servo only responding once after reset
Same thing happening in Stand Alone mode.
Downgrading to 3.3.0 solves the problem.
Thanks for the report.
Would you be able to test with this updated beta?
https://www.dropbox.com/sh/i5vox3xmkd55gaz/AAC19mI0WEC5GmEjLOBRbKs-a?dl=0
I have tested using the servo using the link you have provided in stand alone mode:
Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.0beta7+7 (2022-01-14)
Same thing is happening. Servo only moves once initially.
Thanks
@vollnormal Does it stop working immediately as in:
M280 P3 S90 M280 P3 S120 ; <<--- This doesn't work?
Or do you do anything else inbetween?
Mostly asking in selfinterest as I have some problems running my servos but that's probably not realted to this at all.
@gixxerfast said in RRF 3.4.0beta7+5 SBC Servo only responding once after reset:
M280 P3 S90
M280 P3 S120 ; <<--- This doesn't work?Correct. Any command after the first (M280 P3 S90 in this case) is ignored.
Doesn't help the OP, but the servo on my MB6HC with 3.4.0beta7+5 and SBC (Pi4) is behaving as it should. I have a daemon.g that moves a servo according to enclosure temperature and that seems to be working OK, plus repeated
M280 P1 S170
andM280 P1 S10
switch it back and forth happily. -
If your misbehaving servo is using io1.out on the mini5+ you should try the firmware build in the thread for my issue.
The corrected firmware for the Mini5+ is at https://www.dropbox.com/sh/hx23neagiljflv2/AADxC8_URWgoU_NYcYP8b7XCa?dl=0.
I'm having the same Issue running a servo on a toolboard v1.0 on the io0.out Port.
Mainboard is Duet3 6HC + SBC
M280 P0 S80 works as expected the first time, but only once.
I just upgraded to RRF v3.4.2 but still no luck.
@niocio01 please start a new thread to describe the issue you are seeing, because the title of this one is not appropriate.
