What firmware version are you using?
Most probably it is some mistake in panel due manual operation, that made me change from - to + tool offset. It seems it is ok now
Currently running 2.05 on both my machines, but plan on switching to whatever is latest at the time when changing the kinematics of the portable printer (currently polar swing-arm but it's a bit flexy, changing it to corexy).
Main printer is hooked up to looks of external stuff and using outputs for things that they probably shouldn't be so will have to rethink before upgrading as that's a big job and it's currently working!
How well does the RRF3 firmware run on the Duet2? It has less compute power than the Duet3, so, while I know it is possible, does it handle conditional gcode well, or is it underpowered?
@GeneRisi said in What firmware version are you using?:
It runs it perfectly fine. There are no limitations or draw backs running RRF3 on the Duet2 series boards. Even the Maestro.
Yep I can confirm that, been running RRF3 since it came out on my Duet 2 Wifi and there is nothing negative about it. Works perfectly fine and all the goodies are so worth the switch.
@generisi I can confirm that it runs perfectly fine and fast as well.
I had the "Operation 3 failed" Wifi problem (https://forum.duet3d.com/topic/21562/firmware-bundle-3-2-2-released/) when upgrading from 3.2.0 to 3.2.2 though.
2.05 on all machines. Too much on my plate. But one day I will simply do all machines.
@phaedrux I tried the latest beta version but found the addition of a P parameter to define a spindle tool in the M3 command problematic - so went back to 3.2. I got it working but suspect using/gearing up for multiple tools (tang knife, laser, plotting-pen and spindle) will be over complicated by this. Possibly having to to use separate post processors for each tool, instead of using the tool number in the tool database to determine the tool I am using.
@educatingsavvas said in What firmware version are you using?:
You only need the P parameter if you are in CNC mode and you want to control a spindle that is not the one used by the active tool.
@dc42 Does that mean if R in M950 and P in M563 are the same number during CNC mode, I would not need to write P# when using an M3 command? Should any spindle defining commands be in the tfree#.g tpre#.g and tpost#.g? That is to say I load the spindle separately from config.g file?
I think the confusion with CNC is that you have the spindle and the bits, or tangential knife and blades are referred and all are referred to as tools. And that on a CNC mills the tool database in often part of a complicated control system, while for flat-bed panel CNC machine the tool database in part of the CAM software.
Yes.
There is no need to do that. In config.g, define all your spindles, then for each tool specify which spindle it uses in its M563 command.
3.4 beta2 on my Flsun QQ-S pro with duet3d 2 wifi. upgraded today. I had 3.3 beta 2 before this. All working as it should.
The reason I upgraded was the bugfix for loosing z0 position of bed when homing delta. And I want to try out the accelerometer part. just gotta get the accelerometer and hook it up next week.
3.4 beta 2 but has some problems I'm not happy
@massimilianoconti said in What firmware version are you using?:
Well it is a beta version.
I never attempt to use a beta version in a production printer but I will test them on my workbench where I have a set of electronics for just for testing things like that.
@fcwilt ok however even previous versions like 3.3 were not so good, every now and then it turns out an inconsistent behavior that has no logic. there is something in the firmware that is not good is not reliable completely. I also have a zortrax and I assure you that it does not miss a beat does what it must always do perfectly
What problems are you seeing?
I have four printers using very different designs all running 3.3 on both Duet 2 and Duet 3 hardware and they print just fine.
well i have 3.3 but it has rendered my printer useless
@jujudelta Same here, My setup is exactly same.
3.4.1. It's not in the poll.
undefined Phaedrux locked this topic
undefined Phaedrux unpinned this topic
