What firmware version are you using?
@educatingsavvas said in What firmware version are you using?:
Does that mean if R in M950 and P in M563 are the same number during CNC mode, I would not need to write P# when using an M3 command?
Yes.
Should any spindle defining commands be in the tfree#.g tpre#.g and tpost#.g? That is to say I load the spindle separately from config.g file?
There is no need to do that. In config.g, define all your spindles, then for each tool specify which spindle it uses in its M563 command.
3.4 beta2 on my Flsun QQ-S pro with duet3d 2 wifi. upgraded today. I had 3.3 beta 2 before this. All working as it should.
The reason I upgraded was the bugfix for loosing z0 position of bed when homing delta. And I want to try out the accelerometer part. just gotta get the accelerometer and hook it up next week.
3.4 beta 2 but has some problems I'm not happy
@massimilianoconti said in What firmware version are you using?:
Well it is a beta version.
I never attempt to use a beta version in a production printer but I will test them on my workbench where I have a set of electronics for just for testing things like that.
@fcwilt ok however even previous versions like 3.3 were not so good, every now and then it turns out an inconsistent behavior that has no logic. there is something in the firmware that is not good is not reliable completely. I also have a zortrax and I assure you that it does not miss a beat does what it must always do perfectly
What problems are you seeing?
I have four printers using very different designs all running 3.3 on both Duet 2 and Duet 3 hardware and they print just fine.
well i have 3.3 but it has rendered my printer useless
@jujudelta Same here, My setup is exactly same.
3.4.1. It's not in the poll.
undefined Phaedrux locked this topic
undefined Phaedrux unpinned this topic
