delta smart effector hightmap mess
i got rid of x0 y0 z0 and the extra space didn't make a difference, here are my M98 and M122 P"config.g"
M98 P"config.g" HTTP is enabled on port 80 FTP is disabled TELNET is disabled
M122 P"config.g" === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later Board ID: 08DLM-996RU-N85T0-6J9FL-3SD6M-1SSMN Used output buffers: 3 of 24 (14 max) === RTOS === Static ram: 23460 Dynamic ram: 72536 of which 60 recycled Never used RAM 16024, free system stack 101 words Tasks: NETWORK(ready,193) HEAT(blocked,307) MAIN(running,472) IDLE(ready,19) Owned mutexes: WiFi(NETWORK) HTTP(MAIN) === Platform === Last reset 00:11:55 ago, cause: software Last software reset at 2021-03-19 23:14, reason: User, GCodes spinning, available RAM 16060, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU temperature: min 33.8, current 35.3, max 35.8 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: position 106237, standstill, SG min/max 0/368 Driver 1: position 125544, standstill, SG min/max 0/386 Driver 2: position 149846, standstill, SG min/max 0/362 Driver 3: position 0, standstill, SG min/max not available Driver 4: position 0, standstill, SG min/max not available Driver 5: position 0 Driver 6: position 0 Driver 7: position 0 Driver 8: position 0 Driver 9: position 0 Driver 10: position 0 Driver 11: position 0 Date/time: 2021-03-19 23:26:07 Cache data hit count 747146687 Slowest loop: 42.73ms; fastest: 0.16ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.9ms, write time 9.2ms, max retries 0 === Move === DMs created 83, maxWait 84543ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 587, completed moves 587, hiccups 614, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP is ready with "M122 P"config.g"" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 149.92ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 84:0d:8e:b3:bc:a6 WiFi Vcc 3.38, reset reason Turned on by main processor WiFi flash size 4194304, free heap 20248 WiFi IP address 192.168.178.66 WiFi signal strength -74dBm, mode none, reconnections 0, sleep mode modem Clock register ffffffff Socket states: 0 0 0 0 0 0 0 0
Try updating to 3.2.2 by uploading this zip file as is to the system tab.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2.2/Duet2and3Firmware-3.2.2.zip
Such an exaggerated cone shape of the heightmap seems to indicate a rod length problem based on this: http://boim.com/DeltaUtil/CalDoc/Calibration.html
I've never seen anything so extreme though.
Can you post your bed.g as well?
im going to make the firmware update now.
The rods i got are made by Haydn Huntley's and labeled each 440.35 one of them is 440.34i tried a couple different bed.g files. My understanding was that the bed.g isn't used for g29 which is run before delta calibration G32 but for all i know this might be totally wrong.
On the side i ordered another smart effector.M561 ; clear any bed transform ; If the printer hasn't been homed, home it if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed G28 ; Probe the bed and do auto calibration G1 X0 Y0 Z10 F10000 ; go to just above the first probe point while true if iterations = 5 abort "too many auto calibration attempts" G30 P0 X0.00 Y150.00 Z-99999 H0 if result != 0 continue G30 P1 X96.42 Y114.91 Z-99999 H0 if result != 0 continue G30 P2 X147.72 Y26.05 Z-99999 H0 if result != 0 continue G30 P3 X129.90 Y-75.00 Z-99999 H0 if result != 0 continue G30 P4 X51.30 Y-140.95 Z-99999 H0 if result != 0 continue G30 P5 X-51.30 Y-140.95 Z-99999 H0 if result != 0 continue G30 P6 X-129.90 Y-75.00 Z-99999 H0 if result != 0 continue G30 P7 X-147.72 Y26.05 Z-99999 H0 if result != 0 continue G30 P8 X-96.42 Y114.91 Z-99999 H0 if result != 0 continue G30 P9 X0.00 Y75.00 Z-99999 H0 if result != 0 continue G30 P10 X64.95 Y37.50 Z-99999 H0 if result != 0 continue G30 P11 X64.95 Y-37.50 Z-99999 H0 if result != 0 continue G30 P12 X0.00 Y-75.00 Z-99999 H0 if result != 0 continue G30 P13 X-64.95 Y-37.50 Z-99999 H0 if result != 0 continue G30 P14 X-64.95 Y37.50 Z-99999 H0 if result != 0 continue G30 P15 X0 Y0 Z-99999 S8 if result != 0 continue if move.calibration.final.deviation <= 0.07 break echo "Repeating calibration because deviation is too high (" ^ move.calibration.final.deviation ^ "mm)" ; end loop echo "Auto calibration successful, deviation", move.calibration.final.deviation ^ "mm" G30 S-3 G1 Z50
; Probe the bed at 6 peripheral and 3 halfway points, and perform 6-factor auto compensation ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g. ; bed.g file for RepRapFirmware, generated by Escher3D calculator ; 16 points, 6 factors, probing radius: 170, probe offset (0, 0) ; Auto calibration routine for large delta printer ;M561 ; clear any bed transform ; If the printer hasn't been homed, home it G28 ; Probe the bed and do auto calibration G1 X0 Y0 Z10 F10000 ; go to just above the first probe point G30 P0 X0.00 Y190.00 Z-99999 H0 G30 P1 X122.13 Y145.55 Z-99999 H0 G30 P2 X187.11 Y32.99 Z-99999 H0 G30 P3 X164.54 Y-95.00 Z-99999 H0 G30 P4 X64.98 Y-178.54 Z-99999 H0 G30 P5 X-64.98 Y-178.54 Z-99999 H0 G30 P6 X-164.54 Y-95.00 Z-99999 H0 G30 P7 X-187.11 Y32.99 Z-99999 H0 G30 P8 X-122.13 Y145.55 Z-99999 H0 G30 P9 X0.00 Y95.00 Z-99999 H0 G30 P10 X82.27 Y47.50 Z-99999 H0 G30 P11 X82.27 Y-47.50 Z-99999 H0 G30 P12 X0.00 Y-95.00 Z-99999 H0 G30 P13 X-82.27 Y-47.50 Z-99999 H0 G30 P14 X-82.27 Y47.50 Z-99999 H0 G30 P15 X0 Y0 Z-99999 S7 G1 Z50
M561 ; clear any bed transform G28 ; home all towers ; Probe the bed at 10 peripheral and 6 halfway points, and perform 6-factor auto compensation ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g. G30 P0 X0 Y184.9 H0 Z-99999 G30 P1 X108.68 Y149.59 H0 Z-99999 G30 P2 X175.85 Y57.14 H0 Z-99999 G30 P3 X175.85 Y-57.14 H0 Z-99999 G30 P4 X108.68 Y-149.59 H0 Z-99999 G30 P5 X0 Y-184.9 H0 Z-99999 G30 P6 X-108.68 Y-149.59 H0 Z-99999 G30 P7 X-175.85 Y-57.14 H0 Z-99999 G30 P8 X-175.85 Y57.14 H0 Z-99999 G30 P9 X-108.68 Y149.59 H0 Z-99999 G30 P10 X0 Y92.4 H0 Z-99999 G30 P11 X80.02 Y46.2 H0 Z-99999 G30 P12 X80.02 Y-46.2 H0 Z-99999 G30 P13 X0 Y-92.4 H0 Z-99999 G30 P14 X-80.02 Y-46.2 H0 Z-99999 G30 P15 X-80.02 Y46.2 H0 Z-99999 G30 P16 X0 Y0 H0 Z-99999 S6
it fails to upload the firmware files
Edit: i managed to install it -
@Lihyon said in delta smart effector hightmap mess:
Edit: i managed to install itthe results aren't much different
Number of points: 277 Probing radius: 185 mm Probe area: 1075.2 cm² Maximum deviations: -0.870 / 15.173 mm Mean error: 7.258 mm RMS error: 4.668 mm
bed.g is G32.
What order are you running things? There should be G28 to home the towers, G32 to do an auto calibration, and then G29 to map the bed surface.
@Lihyon Looking at the errors in your results, one point is measured 15mm above the z=0 datum!
In your bed.g, you need to uncomment the M561 to make sure you don't have mesh compensation enabled when ddoing the calibration. if you don't it will be calibrating a mesh-compensated bed and you'll only bake in the errors you're seeing in your heightmap.
@Phaedrux i found my biggest mistake so far, its silly
M665 R190 L440.35 B190 H415 ; Set delta radius, diagonal rod length, printable radius and homed height
R is supposed to be R230.6.
and i was running M561 - g29 s2 - g29 - g32 but i guess im suppose to do g32 - g29 so i added g29 on the end of my bed.g for nownow im facing this issue that the probe doesn't trigger at some point and runs into the bed but not right away like halve way through probing
21.3.2021, 22:02:40 Error: Z probe was not triggered during probing move while g29 21.3.2021, 21:58:29 Z probe trigger height set to 0.018 mm G30 S-3 included in bed.g 21.3.2021, 21:58:28 G32 Calibrated 8 factors using 16 points, (mean, deviation) before (-0.643, 0.353) after (-0.000, 0.037) Auto calibration successful, deviation 0.037mm
@engikeneer but M561 disables any existing bed compensation or not?
EDIT: well i tried and didn't make a difference -
This post is deleted! -
Maybe a sensitivity issue?
setting the sensitivity just doesn't work its suppose to blink 3 times when changed but does not
example M672 S105:25:255
i found the firmware for it but im struggling to find out how to use Atmel Studio 7 to compile it or upload it
How old is the smart effector? Does it have a revision number on the PCB?
What does it respond with if you send M672 by itself?
its says pcb Revision 2.0 CERL OHL 1.2 on it
and M672 spits outError: M672: No program bytes provided
You don't need to build it, you can download the .elf or .hex file from the release at https://github.com/Duet3D/SmartEffectorFirmware/releases/tag/2.01.
I've noticed oddities with changing the sensitivity of the smart effector. At times, the smart effector seems to lose the sensitivity setting (often after a reset or power off/on) and it has to be set again.
When this happens, about 50% of the time sending either the "set" (M672 S105:aaa:bbb) or "revert" (M672 S131:131) commands does nothing whatsoever in regards to the smart effector LED and I have to power it off/on again.
My suggestion would be to power off the machine, wait 10 seconds, and power it back on again. Then set the sensitivity and see if the smart effector responds properly. (It should blink 4 times in response.)
That's not a valid combination. If the first number is 25, the second number should be
230 (255-25 = 230) -
Thank you for everyone's help i really appreciate it !
After installing a new smart effector it seems to work !@dc42 after uploading .hex to the printer it saves my sensitivity
@garyd9 that was the last puzzle piece i completely misunderstood the instructions givenTo program the sensor, send command M672 S105:aaa:bbb replacing aaa by the desired sensitivity and bbb by 255 - aaa.
Umm.. I thought the only way to update the smart effector's firmware was using special hardware.
Is that ability built into the duet firmware now? (I'd love to get that fix on my smart effector, but didn't think it would be feasible for me.)
@garyd9 i got no clue how the firmware works, but when i remove the hex it only flashes 2 times when i turn on the printer and when i include it i get 3 flashes because of my config. its wierd and i wont question it
@lihyon said in delta smart effector hightmap mess:
(Edit: due to the forum s/w change, I lost track of a reply)
In another thread, @dc42 suggested that the firmware can only updated via special hardware. Just sticking the .hex file on the duet isn't enough:
https://forum.duet3d.com/topic/22399/smarteffector-sensivity-unable-to-change-it
