All Drivers give me disconnected reported by driver
Chances are the error message is telling you exactly what's wrong. The motor phases are incorrect.
First you should identify the motor phase pairs and wire them accordingly.
If you've identified the pairs and are sure you have them wired correctly you can do further troubleshooting.
Ofc i did. As said i first did it like it is supposed to be. It didnt work. And then i tried like everything else possible.
Does it still report the error on all drivers with only 1 motor connected?
Short answer is: it reports it anytime. Dont matter if something is connected or not.
Did it work correctly for your friend before they gave it to you?
atleast he said i did. he is trustworthy. thats the only reason i try to get it to run and not discard it already.
What are the specs of the motors you're trying to use?
@Phaedrux said in All Drivers give me disconnected reported by driver:
https://cdn-reichelt.de/documents/datenblatt/X200/17HM5424DATASHEET.pdf
M906 X1400 Y1400 Z1400
you are running 0.8A motors with 1.4A.
@Veti theyx running fine on this current. on the back, they got written 2.4A. Before i run them also with 1.4 and all was fine. they are pretty beefy
then you posted the wrong spec sheet.
do you have a motor of different make that you can test?
@Veti said in All Drivers give me disconnected reported by driver:
y tested and the same issue
can you measure the resistance between the red and blue wire and between the green and black wire?
1.3ohm between each
can you post a picture of the motor connection on the duet?
ofc, i dont lnow why but ofc
@T3P3Tony u may got any idea ?
Try removing the D2 from the M569 commands in config.g.
