All Drivers give me disconnected reported by driver
atleast he said i did. he is trustworthy. thats the only reason i try to get it to run and not discard it already.
What are the specs of the motors you're trying to use?
@Phaedrux said in All Drivers give me disconnected reported by driver:
https://cdn-reichelt.de/documents/datenblatt/X200/17HM5424DATASHEET.pdf
M906 X1400 Y1400 Z1400
you are running 0.8A motors with 1.4A.
@Veti theyx running fine on this current. on the back, they got written 2.4A. Before i run them also with 1.4 and all was fine. they are pretty beefy
then you posted the wrong spec sheet.
do you have a motor of different make that you can test?
@Veti said in All Drivers give me disconnected reported by driver:
y tested and the same issue
can you measure the resistance between the red and blue wire and between the green and black wire?
1.3ohm between each
can you post a picture of the motor connection on the duet?
ofc, i dont lnow why but ofc
@T3P3Tony u may got any idea ?
Try removing the D2 from the M569 commands in config.g.
@dc42 said in All Drivers give me disconnected reported by driver:
Wont change anything. Started without and just added it as a hope it would help.
Does the white connector and the black connector go to the same model of motor?
If so, one of them has to be wrong.
- The white connector is wired as though Red-Green and Blue-Black are coils.
- The black connector is wired as though Red-Blue and Green-Black are coils.
Those cannot both be true (if the cables are consistent on the other end, and plug into the same model motor).
Please show a photo of where the white cable plugs into the motor and similar photo for the black one.
@Danal said in All Drivers give me disconnected reported by driver:
There is no connector on the motor.
This is my test Setup now because i need my printer working.
Using generic 200steps/rev motors.
@Danal Those steppers come pre-wired. They don't plug in with JST on the motor side.
