Reinstall firmware on duet3, now no flashing led
@bearer your link doesnt seem to be working
@chichirod said in Reinstall firmware on duet3, now no flashing led:
yeah, the forum breaks links with spaces when qouting them from previous posts. I'm sure you can manage to scroll up and find the one that works though. (which is why we don't use spaces in filenames..)
(on the other hand if you have the config.zip file from the reprap configurator and the DuetWebControl-SD.zip that would probably be preferred anyway as the zip file with the sd card contents are for an ooooool duet2wifi running rrf2 and dwc1)
@bearer
Folder PATH listing
Volume serial number is C6AB-A322
G:.DuetDriverFiles.zip tmp.txt +---gcodes
+---macros
+---sysDuetWiFiServer.bin bed.g cancel.g config.g homedelta.g iap4e.bin pause.g resume.g sleep.g stop.g tfree0.g tpost0.g tpre0.g config.json homeall.g homex.g homey.g homez.g Data (D).lnk ---www
| favicon.ico.gz
| html404.htm
| language.xml.gz
| reprap.htm.gz
| index.html.gz
+---css
| Lumen.theme.css.gz
| Sandstone.theme.css.gz
| Slate.theme.css.gz
| Superhero.theme.css.gz
| United.theme.css.gz
| bootstrap.theme.css.gz
| dwc.css.gz
| app.eb4376bc.css.gz
+---fonts
| glyphicons.eot.gz
| glyphicons.svg.gz
| glyphicons.ttf.gz
| glyphicons.woff.gz
| glyphicons.woff2.gz
| materialdesignicons-webfont.4c3075c9.woff2
| materialdesignicons-webfont.88ffecaf.woff
| materialdesignicons-webfont.c7a79340.eot.gz
| materialdesignicons-webfont.2abd86f9.ttf.gz
---js
dwc.js.gz
app.2a4070cd.js.gz
app.2a4070cd.js.map.gz -
@bearer it seems to have both the reprap and index file
two things are relevant;
does it work?
if not, does the M20 command show any files in /www ?(and no it DOES NOT have both files unless you use both the old complete sd card and the new DuetWebControl-SD.zip file... but tbh, two days to put some files on a SD card is a joke. phone a friend and have them come help you).
If it still doesn't work, put it back in the PC, right click on the drive and select Properties, then tell us what is displayed.
@dc42 no still not working
@bearer thanks for the help
That Properties dialog looks OK, so it should be working if the files are in the correct folders. With the card inserted in the Duet, send M39 and report the response. Also post the result of sending M20 P"/" S2.
SD card in slot 0: capacity 15.93Gb, free space 0.21Gb, speed 25.00MBytes/sec, cluster size 512 bytes<LF>ok<LF> -
@dc42 said in Reinstall firmware on duet3, now no flashing led:
M20 P"/" S2
Begin file list<LF>{"dir":"/","first":0,"files":["*overlays","bcm2708-rpi-b-plus.dtb","COPYING.linux","LICENCE.broadcom","bcm2708-rpi-zero-w.dtb","bcm2708-rpi-b.dtb","bcm2708-rpi-cm.dtb","issue.txt","bcm2708-rpi-zero.dtb","bcm2709-rpi-2-b.dtb","bcm2710-rpi-2-b.dtb","bcm2710-rpi-3-b-plus.dtb","bcm2710-rpi-3-b.dtb","bcm2710-rpi-cm3.dtb","bcm2711-rpi-4-b.dtb","bootcode.bin","cmdline.txt","config.txt","fixup.dat","fixup4.dat","fixup4cd.dat","fixup4db.dat","fixup4x.dat","fixup_cd.dat","fixup_db.dat","fixup_x.dat","kernel.img","kernel7.img","kernel7l.img","kernel8.img","start.elf","start4.elf","start4cd.elf","start4db.elf","start4x.elf","start_cd.elf","start_db.elf","start_x.elf","wpa_supplicant.conf","*System Volume Information"],"next":0,"err":0}<LF>End file list<LF>ok<LF>
@bearer said in Reinstall firmware on duet3, now no flashing led:
@chichirod its close enough but if that card doesn't display the files with the M20 command then I think you may have formatted the card with incompatible file system or used a different card?
it needs to be fat32.
@bearer as per the picture below it is formatted with fat32
its still not the same card that its in the duet3 board according to M20.
thus different card in bold(or possibly the same card but the wrong partition)
@bearer it for sure is the same card, however im not sure why when i take it from the duet and put it into an adapter to fit in my computer that it says its only a 3gb card when in fact its a 16gb. When i formatted the card there were no partitions
winows key + x -> disk management screenshot
(or just format it properly with https://www.sdcard.org/downloads/formatter/ )
@bearer
@bearer i can also try your formatting link
yeah, you'll need to use F: or format the card
@bearer i just downloaded the formatting program so ill do that.
