Laser Filament Monitor - Testing
Same here. Modded Ender3 now with duet wifi and titan aero 1.75, using a variety of filaments.
Waiting for parts and then will build a HEVO with the duet. The filament sensor would be amazing for it -
We have a pre-production batch almost ready to ship. More news soon.
I knew there was something else I wanted to ask you guys about at TCT! Having lost my big 24V core xy system through redundancy I'm down to my v0.6 (x3!) and 12V.
Are the current revisions likely to play well with the Maestro boards along with the Duet 2?
@doctrucker the filament monitors will.work on the Maestro, Duet 2 and we plan for forward compatability to future versions of Duet.
Thinking about this a little further could I hook the development sensors to a spare arduino due and just read distances from it? With a bit of coding? Is the rotating magnet version mentioned on the documentation likely to be more reliabke than the laser based or are these questions for the trials to answer?
@doctrucker yes you can
Rotating magnet is very accurate across all filament types. -
Very interested in trying it from that perspective then. It'll be far superior to me measuring filament by eye with a 150mm metal rule! Where can I express an interest in buying a beta model of the magnet based sensor - or is it not ling to wait for the planned commercial release? I realise the date may slip due to beta trial results.
I have been using my laser sensor now for a short while. With black PLA I had mostly consistent results. I started using eSun yellow PETG and made several small prints with the same travel numbers. Last night I started a vase mode part and it got to about layer 160 before it stopped. The reported low number was 24%. I restarted the print and it went another 10 layers and stopped again. The restart was perfect, but the layer adhesion was non-existent. It printed another 10 or 15 layers and stopped again with 24%. The average range up to this part printing was 84% to 94%. When I checked the vase as the print was getting started it was also 85 to 95%. I'm not sure what is going on. The filament feed is not restricted and I'm using a Bondtech extruder. The quality of the print was as near perfect as I could ask for, and I'm using a fairly high temp so the nozzle is very unlikely to be getting clogged. I had the print speed at 40mm/s.
Ideas? Does retraction mess with the sensor? In vase mode there should be no retraction.
I have yet to install the laser sensor in my second printer, but it's ready to go.
@3dmntbighker the sensor performs differently depending on the filament types as you have seen. For PETG we have reports that ESUN Black was very poorly registered which I have confirmed on tests. I have not confirmed for ESUN yellow PETG however it looks like that is also not good. If you are getting +'ve numbers you can increase the trigger window for that filament.
@t3p3tony said in Laser Filament Monitor - Testing:
Very odd that it goes from 85 to 95%, then suddenly out of nowhere it's 24% with no change in speed, feed rate or filament type.
@3dmntbighker yes that is strange. I found the ESUN black PETG very variable with unworkable results, however other PETGs (specifically e3d edge) are not as variable.
Well, I have stopped buying eSun altogether. My standard filament brand is now 3D Solutech. I also use a mix of Taulman, Filamentum and others. I hope they get Prusament on Amazon soon.
@3dmntbighker will be very interested to hear how you get on with those other brands!
Hi...
When you estimate filament monitor will be reléased? And the Price?
Thanks
