Panel Due stopped working
@phaedrux Oh ok thx, i was looking at that but thought it was for duet v2. I cant connect to web control so need to usb and sdcard if thats possible.
Is it a duet2 wifi v1?
@phaedrux I dont know. When i bought it it was just duetwifi, there wasnt anything newer. Now i see duet v2?
I just tried duet2combined by copying it to /sys folder on sdcard and ran m997 s1 command from tft. It reponded by "duetwifiFirmware not found."
so i renamed it as was required before. Ran the m997 command again and it said duetwifiserver not found,
so i copied duetwifiserver bin to /sys folder and ran m997 again and this time it installed successfully and reported
this;Firmware Name: RepRapFirmware for Duet WiFi Firmware_Version 1.19beta7
Electronics: Duet WiFi 1.0 Firmware_Date; 2017-06-22So seems thats not correct.
Have you updated the IAP files? Update those are try the firmware again.
@phaedrux No, ok found those, i assume they go in /sys folder?
Copied IAP4E.bin to sys folder.
No change.
Deleted DuetwifiFirmware file from /sys folder
copied Duet2CombinedFirmware.bin to /sys folder and ran M997 S1 command and it reported Success
ran M115 to check and it reports same as before 1.19beta 7
I think there are 3 IAP files.
You could also try upgrading to the full version of 1.19 first in case it's an issue with upgrading from a beta firmware.
@phaedrux Ok thanks, i will do that.
Installed v1.19+6. The version update does update to this version.
No change as far as the panel duo working right, tho.
When i run the macro "setNetwork" it returns;
Macro file: "0:/macros/setNetwork" not found. also same as before
@brian said in Panel Due stopped working:
No change.
Rename your downloaded Duet2CombinedFirmware.bin file to DuetWiFiFirmware.bin, upload it, and accept the invitation to install it.
After a lot of trying i finally had the idea to flash it with my tablet and its working again.
I dont know whats the problem with my pc.
Tested different cables, usb-ports and versions of bossa. -
@pat said in Panel Due stopped working:
Tested different cables, usb-ports and versions of bossa.I'm glad you got it working again. I don't understand what caused the problem, because Bossa from a PC should work as long as you:
- Download the correct firmware file correctly, and select it in Bossa.
- Check the Erase All, Lock, and Boot To Flash buttons before pressing Write.
- After the Write finishes, press Verify. I have known Bossa to say that the write is complete, but for the Verify to fail.
@dc42 Thank you, it now updated to v2.0(RTOS) and i have full function on the panel due ftf.
However still cannot connect to network.
I suggest you run M122 to check that you have DuetWiFiServer 1.21 installed.
@dc42 M122 reports;
WifFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later Board ID: ....a very long sequence of letters.Nothing else.
The wifi firmware version is given in the Network section of the M122 report, unless the WiFi is still in the Disabled state.
