Corner LEDs not working
I know that it is the resistor R9 that is why I am asking. And no I did not connect to 24v I have a totally 12v system. I just need to know what resistor to use to replace R9.
R9 doesn't matter on a 12V system because it it bypassed by the 12V jumper. Have you fitted that jumper?
yes. They were working fine. It is to be honest my fault, instead of changing connectors on my fans every time i change them I decided to change the connectors on my effector and while soldering them on I think I overheated the resistors. And then while testing for voltage like you describe above (checking from hot end fan - to leds for voltage the leds would light up and I would read voltage.
by the way this incident also finally induced me to buy a rework station with temp control and retiring my old radio shack dual wattage soldering iron.
Hi I think I have probably broken my LEDs as I changed from a 12v hotend heater to a 24v one and did not remove the jumper, they did work for quite a while then stopped working.
If R8 is the problem, I will attempt to fix it, what resistor should I use?
R8 is 140R 0.33W. The schematic is at https://github.com/T3P3/SmartEffector/blob/master/SmartEffector/SmartEffector_v1.3/SmartEffector_Schematic_v1.3.pdf.
Thanks David.
Okay so, I ordered a new Smarteffector PCB and swapped it out.
Rebuilt it with the new PCB (LED jumper OFF this time - 24v) and it works fine.
But on taking a look at the old one, the R8 resistor looks a little toasty but still reads 140Kohm.
Maybe it's just not very well soldered?
NB it's worth stating that I am running my smart effector 3 corner LEDs by connecting the hotend fan connector on the smart effector to the heater in parallel as I now have watercooling and the hotend fan isn't wired up anymore, I needed the two cores in my wiring loom for a thermistor for the heatsink. The PWM to the LEDs shouldn't be a problem should it?
PWM to the LEDs is OK. As you were previously running the LEDs well above their normal current, perhaps one of them has blown? Let me know if you need a replacement.
Thanks David, I bought another piezo effector pcb, it was my fault they blew, I should have taken the jumper off. I can replace or possibly just resolder the resistor and press the broken one into service elsewhere. I'll check the leds. Hope you had a nice Christmas.
I meant a replacement LED so that you can mend the old one.
Okay thanks will let you know.
The 3 white corner led on / off is possible , or light ever time when printing ?
Thanks -
The corner LEDs should illuminate when the hot end fan is powered, if you have the wiring polarity correct.
Ok thanks for response DC42,
It is boring to always see the LEDs ON, especially at night with long prints. There is no possibility to switch them on / off with a command. Thanks again
