Why does my Z hop sound like a hammer.
How can I quiet down my printer Z hop, This is Voron 2.4 3d Printer, <4> Z belts.
; Drive directions M569 P0 S0 ; A M569 P1 S0 ; B M569 P3 S1 ; Extruder M569 P5 S0 ; Z1 M569 P6 S1 ; Z2 M569 P7 S0 ; Z3 M569 P8 S1 ; Z4 M584 X0 Y1 Z5:6:7:8 E3 ; Motor mapping and steps per mm M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E562.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X60000.00 Y60000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2) ; Drive currents M906 X1500 Y1500 Z1200 E400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout
Try reducing the acceleration.
@Phaedrux on Z like this
M201 X6000.00 Y6000.00 Z4000.00 E250.00 ; set accelerations (mm/s^2) M201 X6000.00 Y6000.00 Z1000.00 E250.00 ; set accelerations (mm/s^2)```
That's a good start.
@Phaedrux
I still wouldn't recommend using Z-hop on a moving bed printer. There are so many possible side effects when moving a big mass.
I'd switch it off after the first layer. That's where it is most critical not to scrape the nozzle over the fresh print. -
@Karim how much Z hop are you using?
@dc42 I am using Prusaslicer 2.5 and this is the only setting I see Z Lift. This printer the Bed is fix and the Nozzle move up and down (Corexy).
@Karim that looks reasonable, although you could try using less. I typically use one layer height.
@dc42 I am using .6 Nozzle and print @.3 layer height. So what else can I check.
Did changing the acceleration help?
Do you have the tension of the Z belt gear reduction set correctly?
@Phaedrux lowered Z speed. Sounds better now.
Thanks. -
