Tired of my delta printer...
@peirof another option is the BLV MGN cube. You can get kits on Aliexpress that are reasonably complete. It also uses a Duet WiFi by default (though all the kits will come with cloned boards, but you can get them without the board and buy a proper one)
The design and documentation might be slightly less complete than the Vorons, but I think its a slightly simpler machine which might be easier to setup.
Either that got go for a complete printer out of the box e.g. an Ender 5 -
@peirof said in Tired of my delta printer...:
I'm tired of my delta printer....
The last thing is that another duet board has fallen, and it's the second...I'd start over building a new printer only when I've found the reason for the Delta to grill Duets.
If it's lack of knowledge or some misunderstood documentation, your next project will fail, too.Sorry, if it sounds harsh, but I'm trying to save you some money..
@peirof Have a look at the Rat Rig V-Core 3
Default: https://www.ratrig.com/3d-printing-cnc/3d-printer-kits/v-core3default.html
Configurable: https://www.ratrig.com/3d-printing-cnc/3d-printer-kits/v-core3configurable.html -
think you have reason....
It is the great fear that I have, that I mount a new printer, and that for something that does not do well ... I will burn a Duet plate again ... But the other option is almost worse, if I change the Duet plate, in my current one printer, without changing practically anything ... I'm condemned to fry another board ... and I don't know how to get out of that loop .... when the Duet v2 board arrived, I was happy because it had more fuses than 1, and I thought that he was protected ... but apparently it wasn't enough.
My biggest fear, mounting a new printer, and burning another duet board again .... but I DON'T know how to deal with the problem
@peirof main thing to do is to test. Get a multimeter and test all your connections. Check for shorts to ground, shorts to Vin etc.
Reading your other thread, it sounded like you had a short somewhere in your hotend wiring which needed diagnosing and fixing before the Duet was powered up... even if the Duet has fuses, they take a (small) amount of time to blow so won't always protect your board from that kind of damage
@engikeneer said in Tired of my delta printer...:
I haven't seen that thread, but another where a Duet1 board has a burnt driver chip. The error seems to be in wiring/electronics mishaps.
Available in different sizes from 200x200 up to 500x500. All metal design.
Thanks to all...
For the moment I have 2 preselected printers:
- Rat Rig V-Core 3
- Voron Trident
Its easier purchase Rat Rig components...
Some options of those printers?
I would say, stay away from bowden extruders, go with direct ones.
My 2c.
I'm studying the options, for the moment I think I'm staying with the Ratrig...
Maybe I like the idea of the Voron better... But the configured Ratrig website, makes getting the components much easier than the voron.
I have a doubt, after using the configurator, I do not know if you have tried it ...
And it is that when choosing the board gives you the option of Duet v3 mini (it is the idea I had, for that perfect face) but adds:
- Duet 3 mini
- v1 WiFi with Duet v3 (I suppose I guess this will be to add WiFi to the duet 3 mini)
- Dual steppers expansión board (Ratrig uses 5 steppers motors, duet 3 mini have 5 drivers... Why this expansión board?)
Someone can give me feedback about these printer?
Thanks
It's possible that they use 3 independent Z motors? (+ two for X/Y and one for extruder) and thus needs the expansion to drive the 6th motor.
The 'V1' is the version of the Duet Mini5+ Wifi. Github shows two versions, 1.0 and 1.01. Not sure what the differences are.
I think it depends a bit on what material you want to print. Do you want to print ABS/ASA/PC then you'll want an enclosed printer.
I would recommend a Voron for that, a Trident or the 2.4. Yes, the 2.4 has some challenges, it has a flying gantry and four z-motors but it's very well designed and together with some mods it's a print-and-go machine. It requires that you understand it though, it's not an Ender 3.
As with all enlosed printers that get's a higher chamber temp you will have heat expansion that can be a problem if you don't understand it. It can be handled with Auto Z-correction and mesh compensation with large prints. Or you always print with the same circumstances.
The community is large or rather getting huge, though we are a fewerbunch using Duets but it works really nice with the 1LC toolboard. Just four cables to the toolhead. It is though an DIY printer for people who want to build a printer themself.
Tuned it can produce great prints. Small example in ABS (greatly enlarged. It's about 3 cm across):
If you want mainly a PLA-printer I would go with maybe another machine, open frame or where the enclosement is more of an afterthought.
@gixxerfast said in Tired of my delta printer...:
I see, that you have a Voron....
How did you get the materials?
Did you take the BOM from the web, and you were buying them separately?
Did you buy a pack? Web?
The printed parts ... did you buy them, or did you print them?As I have said, I like the Voron more, but finding the materials to make it seems more complicated, although I already have part of them ...
I have started to build me a little teststation, where I test all electronic components before I use it with a Duet:
- endstop
- steppers (with Arduino and Pololu)
- SSR
- hotend circuit
- wires with crimping (I've still problems to crimp)
So I know that the electronics are ok (no short circuits, right poling) before I "set the Duet under danger".
@peirof I bought the parts from mainly a couple of sources, Fermio (DE), Lecktor (EE) and AliExpress (Powge and Trianglelabs and a few more). Then a few bits here and there and the Duet boards from Denmark.
I built an Ikea Lack enclosure for my Ender 3 and printed the first parts on that in ABS/ASA. Then I have reprinted most parts on the 2.4 itself as I have modified it.
Yes, there are so many now that want Voron parts, but checkout the Voron Discord there you will get heap of info, almost too much
A very friendly and helpful bunch https://discord.gg/voron
@joergs5 said in Tired of my delta printer...:
Seems a good tip...
but... how do you know if a component its wrong? Check continuti, voltage?
At the moment it depends on the component, but in most cases yes. Sometimes only a check whether it works. And I'm trying to do the best to stay at a specific color coding if possible, black always ground, red 24/12/5V/3.3V, steppers black+green together. (that's easy to remember for me: black and green political parties in germany).
@gixxerfast
thanks, i go to the Discord.... -
@o_lampe It is one of the components that I thought to reuse from my current printer
