I want to use 3 Extruders
Hey, thank you for your fast reply.
I am also thinking a new board like Duet3 is the best solution.
Do you know if the Duet3 MB6HC has the same size like the duet2 wifi?
And is it possible to use my existing Panel that is now connect to my Duet2 wifi? -
Duet 3 MB6HC is larger than Duet WiFi. Duet 3 Mini is the same size and has the same mounting hole positions, however the connectors are in different places. Both support PanelDue displays.
The MB6HC has more powerful stepper drivers than the Duet WiFi. The Mini has less powerful drivers. See https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics for a summary of the differences.
Hey, i am now at home and play with my Duet2 wifi and 3 in 1 out Hotend and extruders.
I connect 2 extruders to duet2 to see how it works.
In the moment i want only use 2 extruders.1 Extruder is working fine.
I try to setup my config.
But i don´t see at DWC my second extruder so i can´t switch.What do i wrong?
@uneumann36 It's hard to say what you've done wrong unless you tell us what you've done. Suggest you post your configuration file, then one of us might be able to help.
Btw, if you only load filament into 2 of the 3 inputs, then things will get very messy because filament will be forced back out of the unused input.
Thank you for your answers
So i am Not a Programming guy, so i do ist by learning by doing.
In this First step i will Try to keep this working
The Print Results are Not importent in the moment.So do i Unterstand Right ? When conifg is right, i can Heat up the hotend, make on dwc for example extrude 100 mm filament at 2mm/ sek.
And on dwc i can swop from one to the other extruder by selecting tool??? -
Any feedback about my question?
@uneumann36 The answer is yes
Ok, thank you very much.
And sorry for the may stupid question from me.
But as i told you, the programming stuff is not my favorite,
and i have to learn a lot ! -
@uneumann36 You asked the question "What have I done wrong?" How can anyone answer that when you won't tell us what you have done? I say again, post your configuration file, then we can see.
Hey all good!
I want to say thank you , all this information bring me forward.
ANd i will post my config when i am home -
Hey Guys
I am back home and play with my printer and extruder.Of course i am playing in the moment. I will try to heat up the hotend, und make hand extrusion via DWC from extruder 1 and after this extruder 2.
So i make a new config via config tool and bring it to printer.
Now i see 2 Tools , and Bed.
If i switch on tool on, both goes on. and also off when i switch on off.How to test both extruders via DWC ?
Here my config , hope someone has an idea. :
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu May 06 2021 17:04:43 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M550 P"ENDER 5 Duet" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S1 ; physical drive 4 goes forwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1500:1500 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X220 Y220 Z300 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M563 P1 D1 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
Hi Guys
At least i get my THC-01 working.
But i am not really happy how it works.Also i do not know how to slice a object.
May somebody has experiance with this hot end.
And a question from my side:
Is it possible to change the extruder while printing with no fail?
So that extruder 0 pull back filament 30mm and extruder 1 push filament 30mm and continue printing?
How can this work?Regards
Uwe -
@uneumann36 Yes you can do it, but you need to set a few things up. FYI I don't have a hotend like yours, but I do use a multi-tool printer (E3D chimera) - will try and make it relevant for yours.
Step 1 - you need to define the tool change macros that get executed when you switch between Tool 0 & Tool 1. You'll find information on these here:
https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_filesYou can set up most of this in the slicer, but I find it more intuitive to put in the printer itself.
I think in tfree0.g & tfree1.g you'll add the retract 30mm (though the amazon product description I read says 45mm!). e.g.
G1 E-30 F300 ; retract 30mm @ 300mm/min
I think in tpre0.g & tpre1.g you could put the movement command as the docs suggest, or leave blank
Then in tpost0.g & tpost1.g, you would de-retract the 30mm (or 45mm!). e.g.
G1 E30 F300 ; deretract 30mm @ 300mm/min
In your slicer (I use PrusaSlicer), you will need to setup your printer as a multi-tool (or multi-extruder) printer. That then should open up the settings you need.
In PrusaSlicer, you can import a pair of STLs (one for either tool) and it will allow you to select the tool for either one. It will then put the 'T0' and 'T1' commands in the correct places to switch tool through the print.
You will want to play around with a few of the settings in your slicer (e.g. maybe using a prime tower). You may also need to tweak the tool change macros a bit (e.g. faster/slower retract/unretract, change the distance etc).
It can all be a bit complicated and will take quite a bit of tuning to get it right, but you'll get there
@engikeneer
Thank your very much for your feedback.Unfortunatly i have not big experiance in programing stuff.
Let me say, in the moment i just can swim a bit.Could you explain me how to do this, what is the exact code for this, and how and where to put it in?
I am sorry for my stupid question.
Or any other guy can help me?
I try different things, so i am to stupid to adjust this.
What part of @engikeneer's excellent reply are you getting stuck on?
You can't expect strangers on the internet to create a perfectly working configuration for your printer. Even if we wanted to, we don't know exactly what you have. You'll need to read and research and learn as you go. We can answer specific questions, but you'll have to give us something to work with.
@phaedrux
First, i am very sorry for my last comment.
Because i am frustrated why i can´t get this working.
But the explanation of you and your colleagues are super perfect.
Maybe i am to stupid.Maybe i understand this wrong!
I would keep my triple working in two steps.
First, change filament with DWC myself while printing.
If this is working , i can try to do it inside of the slicer.For my better understanding :
It is possible to change the filament while printing?
For example : I print a part that is normal sliced , and with DWC i change the Extruder by hand. And the software pull back the filament automatically the stored length , and the requested Extruder start and extruded the stored length and then continue printing ????
