Software package 3.3beta3 released
@diamondback i use this cable https://www.amazon.de/gp/product/B08BJSK567/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 I cut of the plugs and I crimped it to dupont connectors thats all
@siam Any specific pins for specific functions? Or just randomly took what was there?
@diamondback
(picture was stolen at wikipedia
Red = 3.3V
Black = GND
Blue = SDA => MOSI
Yellow = SDO => MISO
Green = CS =>CS3
Orange = INT => CS4
Violet = SCL => SCK
White = NC -
I see that Duet 2 can now do neopixel LEDs, which is super cool, but how do I wire them up and configure? Which pins should I use?
@thebaseddoge said in Software package 3.3beta3 released:
@phaedrux I saw that but it seems to only be for Duet 3 right? Duet 2 has no NP_LED pins
@thebaseddoge Correct. Duet2 lacks the hardware.
Duet 3 MB6HC supports both DotStar and NeoPixel LED strips. Duet 3 Mini supports NeoPixel only. Duet 2 and Duet Maestro do not support these LED strips directly, but you can use an Arduino to interface them to a Duet.
@phaedrux Right, but this line in the 3.3beta3 changelog implies that Duet 2 can now do it. That is where my confusion comes from.
Bit-banged NeoPixel LED strips are supported on Duet WiFi/Ethernet. On these boards RRF will wait stop movement while updating the LED strip, so M150 commands should not be issued while the machine is printing, other than at places where a short pause is acceptable such as at layer change and in the start and end scripts.
@thebaseddoge I think a pin has been enabled for controlling the Neopixels on 12864 displays. But I don’t know if it works outside this use case. Will need some @dc42 guidance.
@droftarts I didn't think the Duet 2 Wifi supported the 12864 either, only the Maestro? Hopefully dc42 can clarify everything.
thanks. -
@dc42 I upgraded and noticed user variables in SBC mode are not showing up. I know integration was pulled in b2 and a fix was in the works for 3.3b3... Is this is a bug or have plans changed for user variable integration in SBC mode?
Global variables appear in the Object Model Explorer in 3.3beta3 but changes to their values are not picked up. That is fixed in the forthcoming 3.3RC1.
@droftarts said in Software package 3.3beta3 released:
@dc42 do you have any more info on this? thank you!
@thebaseddoge these are the pins to use when connecting a 12864 LCD to a Duet WiFi/Ethernet:
constexpr Pin EncoderPinB = PortCPin(7); // connlcd.3 -> exp2.6 constexpr Pin EncoderPinA = PortAPin(8); // connlcd.4 -> exp2.8 constexpr Pin LcdNeopixelOutPin = PortDPin(18); // connlcd.5 -> exp1.5 constexpr Pin LcdResetPin = PortCPin(28); // connlcd.6 -> exp1.6 constexpr Pin LcdA0Pin = PortDPin(19); // connlcd.7 -> exp1.7 constexpr Pin LcdCSPin = PortAPin(25); // connlcd.8 -> exp1.8 constexpr Pin EncoderPinSw = PortDPin(20); // connlcd.9 -> exp1.9 constexpr Pin LcdBeepPin = PortDPin(21); // connlcd.10 -> exp1.10 // Additional spi wiring for FYSETC Mini 12864 display: // connlcd.2 (gnd) -> exp1.2 // connsd.1 (+5V) -> exp1.1 // connsd.2 (gnd) -> exp2.2 // connsd.3 (SD CS) -> exp2.7 // connsd.4 (sck) -> exp2.9 // connsd.5 (mosi) -> exp2.5 // connsd.6 (miso) -> exp2.10
Warning! Some displays have the EXP1 and EXP2 connectors the other way round. So don't rely on the exp1 and exp2 pin numbers in the above.
@dc42 I think the question was what pin to use to control Neopixels independently. Is connlcd.5 always available for Neopixels, or only when a 12864 is connected and defined in config.g?
The support in RRF is intended for driving the LEDs on 7567 displays, however I think it should work without a display being configured provided that you don't try to use drivers 10 and 11. You will need to level shift the signal from 3.3v to 5V.
The RGBW Neopixels don't seem to work in 3.3b3 even though it's in the release notes. Is it not implemented yet or am I doing something wrong? -
@nmsmith89, it is implemented. There are new M150 X parameter values for RGBW. I have just updated the documentation at https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M150_Set_LED_colours.
@dc42 I do have a PanelDue 5" display, but i dont have anything on stepper 10/11. so do I just need to use pin 5? what fw config changes are required?
@dc42 Thank You!!!
