RepRapFirmware road map Q1 2021
@dc42 is there a planned improvements spreadsheet for 3.3 similar to the one made available for 3.2? https://forum.duet3d.com/topic/16291/reprapfirmware-3-2-planned-improvements
Really looking forward to the input shaping work that is already happening!
I have a question though.
I'm currently building the wiring loom for my custom toolchanger and was wondering if there is any thoughts yet on whether or not the Duets will have the abilitiy to connect something like an ADXL345 sensor to them for auto calibrating the input-shaping parameters.
If so, is there any preferred connection method yet (I2C vs SPI), if there is, I'd directly include the necessary cables in my loom to the carriage head, which has a built-in mount for such a sensor and save me some headache of having to rebuilt the loom further down the line.Thanks
We are considering how we support stand alone accelerometers connected to Duet 3 mainboards. It is likely to be over SPI connected to the Temperature DB connector as I2C is not appropriate for long distance, off board wiring runs.
@jay_s_uk said in RepRapFirmware road map Q1 2021:
Not yet, because whether some improvements go into 3.3 and 3.4 depends on when DCS 3.3 is ready. But now that 3.3beta2 is out, we have a much better idea. RRF 3.3 is likely to include the improvements already in 3.3beta2, plus the ability to switch tool heaters between off/active/standby without selecting/deselecting the tools, and a few more bug fixes and minor new features.
This post is deleted! -
@fcwilt said in RepRapFirmware road map Q1 2021:
Any chance of having G30 accept X and Y parameters (when no P parameter is present) thus doing the math and movement needed to place the probe at X and Y without needing a preceding G1 command?
If the printer has not been homed then moving to an XY position at the start of a G30 probe move is problematic on some types of printer, e.g. delta printers. So it's possible after Z homing has been done (and the print head would move rapidly to the specified position and dive height before probing), but potentially problematic for a G30 homing move.
@T3P3Tony Perfect, thanks a lot, I will include wiring for 4-Wire SPI then.
@fcwilt Could you move this suggestion to firmware wishlist? I think that would be a more appropriate place to discuss.
@droftarts said in RepRapFirmware road map Q1 2021:
Will do.
@T3P3Tony Any chance for accelerometers to be connected to the 1LC?
@Diamondback said in RepRapFirmware road map Q1 2021:
A quick update: I have determined that we also need an interrupt signal from the accelerometer in order to read the data fast enough. So in total it will need 5 signal wires, plus 3.3V power and ground.
Very excited about the input shaping, especially after this video was released yesterday:
https://www.youtube.com/watch?v=6JBIEJan6zs&ab_channel=Vez3D -
Is there a dynamic roadmap document that is periodically updated somewhere on the Github? I fully appreciate the complexities of working on projects like this and understand dates move, but perhaps a dynamic document with estimates for the next release date and a confidence level would save mods and Duet staffers fielding the same question repeatedly?
'When is RRFx.x.x' coming out mush be a very popular question on these forums!
@doctrucker said in RepRapFirmware road map Q1 2021:
Not yet, but we're working on making our development more transparent after the 3.3 release.
undefined Pit34 referenced this topic
