Homeall Slams head to far corner
This has been an ongoing issue I can't seem to resolve. I can home x y z. Everything works fine. When I homeall it slams the head to the far back corner. Same when I do a G32 bedleveling command. I am going to post all my files and see if anyone sees anything I am doing wrong there.
homeall.g
; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)G91 ; relative positioning
G1 H1 X-500 Y-500 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H1 X-500
G1 H1 Y-500
G1 H1 X-500 Y-500 F360 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X222 Y201 F9000 ; go to first bed probe point and home Z
G30 ; probe the bedconfig.g
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time); General preferences
G21 ; Set units to MM
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode;Network
;M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.4 S0 ; physical drive 0.4 goes backwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P1.0 S0 ; physical drive 1.0 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping
M92 X100.00 Y100.00 Z400.00 E408:408 ; set steps per mm
M566 X600.00 Y600.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X20000 Y20000 Z600 E2000.00:2000.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z600.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
M906 X1300 Y1300 Z1300 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M671 X-55:465:465 Y180:310:45 S9 ; leadscrews at rear left, front middle and rear right; Axis Limits
M208 X Y0 Z0 S1 ; set axis minima
M208 X410 Y410 Z465 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io4.in" ; configure active-high endstop for low end on X via pin !io0.in
M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
;G31 P500 X-40 Y-10 Z1.192 ; set Z probe trigger value, offset and trigger height
;M557 X20:430 Y15:410 S20 ; define mesh grid
Z-Probe
M558 P8 C"^io7.out" H10 F120 T6000
G31 P50 X16.795 Y25.4 Z.3
M557 X20:400 Y20:400 S50; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin temp1
M143 H1 S300
M307 H0 R0.276 C683.100:683.100 D0.20 S1.00 V24.1 B0
M307 H1 R2.032 C110.1 D4.50 S1.00 V24.2; Fans
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S1.0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Tools
;M563 P1 D1 H1 F0
;G10 P1 X0 Y0 Z0
;G10 P1 R0 S0; Custom settings are not defined
T0
M501Bed.g
; bed.g
; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time)
G28 ; home
;M401 ; deploy Z probe
G30 P0 X10 Y180 Z-99999 ; probe near an adjusting screw
G30 P1 X360 Y310 Z-99999 ; probe near an adjusting screw
G30 P2 X360 Y60 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
;G29
;M402 ; retract probe -
@mrenz999 said in Homeall Slams head to far corner:
I re-posted your files using the </> tag - it improves readability and provides scrolling sections for each file.
Please posts your other homing files that you say are working for you.
config.g
config.g ; Configuration file for Duet 3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves G21 ; Set units to MM M550 P"Duet 3" ; set printer name M669 K1 ; select CoreXY mode ;Network ;M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes backwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S0 ; physical drive 0.4 goes backwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P1.0 S0 ; physical drive 1.0 goes forwards M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X100.00 Y100.00 Z400.00 E408:408 ; set steps per mm M566 X600.00 Y600.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min) M203 X20000 Y20000 Z600 E2000.00:2000.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z600.00 E5000.00:5000.00 ; set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M671 X-55:465:465 Y180:310:45 S9 ; leadscrews at rear left, front middle and rear right ; Axis Limits M208 X Y0 Z0 S1 ; set axis minima M208 X410 Y410 Z465 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io4.in" ; configure active-high endstop for low end on X via pin !io0.in M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds ;G31 P500 X-40 Y-10 Z1.192 ; set Z probe trigger value, offset and trigger height ;M557 X20:430 Y15:410 S20 ; define mesh grid Z-Probe M558 P8 C"^io7.out" H10 F120 T6000 G31 P50 X16.795 Y25.4 Z.3 M557 X20:400 Y20:400 S50 ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 M307 H0 R0.276 C683.100:683.100 D0.20 S1.00 V24.1 B0 M307 H1 R2.032 C110.1 D4.50 S1.00 V24.2 ; Fans M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency M106 P0 S1.0 H1 T45 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Tools ;M563 P1 D1 H1 F0 ;G10 P1 X0 Y0 Z0 ;G10 P1 R0 S0 ; Custom settings are not defined ; Miscellaneous T0 M575 P1 S1 B57600 ; enable support for PanelDue M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss M501
homeall.g
; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-500 Y-500 F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H1 X-500 G1 H1 Y-500 G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-500 Y-500 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X222 Y201 F9000 ; go to first bed probe point and home Z G30 ; probe the bed
bed.g
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time) M561 ; clear any bed transform G28 ; home ;M401 ; deploy Z probe G30 P0 X10 Y180 Z-99999 ; probe near an adjusting screw G30 P1 X360 Y310 Z-99999 ; probe near an adjusting screw G30 P2 X360 Y60 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors ;G29 ;M402 ; retract probe
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:21 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-530 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 H1 X-530 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:22 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-530 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 H1 Y-530 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homez.g ; called to home the Z axis ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 X222 Y201 F9000 ; go to first bed probe point and home Z G30 ; home z by probing the bed
@fcwilt said in Homeall Slams head to far corner:
Why is one of these inverted and not the other?
Did you verify that each is working by manually triggering them and running M119?
I forgot to mention that issue with G32 having the same problem is bed.g issues G28 which runs homeall.g which is where the problem is.
@fcwilt both work correctly. Different end stop switches.
@fcwilt so remove the G28 ?
so remove the G28 ?
no fix the problem in homeall.g
Why do you have lines 2 and 3?
that for corexy because they cant move independently.
execute each line of homeall separately and see where the problem is
G30 ; probe the bedIs that the line that makes your head crash?
Why probe at X222 Y201? -
@Veti said in Homeall Slams head to far corner:
This isn't my problem - @mrenz999 was the OP - I'm just trying to help him.
@o_lampe To probe the center of the bed.
@Veti So this is what I did. One line at a time. Commented out the first line G92 and it works correctly now. Strange.
I don't see a G92 in your homeall.g file.
Is that where it was?
