3,3V yellow, 5V red, LED VIN blue Probe not working
@bearer
Hello,sorry for replaying that late....was really in NewYear Startup Stress at work and so on!
So I measured on the Expansion Port 5,0V as well as 3,3V?!?! Crazy isn't it?
Many Thanks in advance for helping me again!
Danijel
O.K. friends,
may tell me someone why the current temprature of HotEnd is dark blue highlitetd on PanelDue? Does that something inform about...Status of what ever?Even if I'm disconnecting Heatercartridge or rahter Sensor!
[Bild Text](Bild Link), it's still dark blue highlighted?!?!
Many Thinas
Danijel T.
Hello @bearer,
checked as requested 3,3V and 5 V on Extentionboard Junction. All fine 5V=5,0V; 3,3V=3,30V. No it's not a genuin Board, its produced by MakerBase in really good quality and until i started the new update of reworking the X-Carridge eveything workt perfekt from the very first second until now....6Months later. No nothig is heated up untypically! You wrote somthing about a soldered Fuse on the Board for the Thermistors.....My you explan where it is located?
Additionally I've registerated that on the GUI of the PanDue the Setpoint for HotEnd the not yet seted setpoint (23°C) is hightlighted dark blue......what does that mean?
If the soldered Thermistor Fuse is broken......would the souruunding temperatures will be displayed well?
Many thanks in adveance !!!Danijel
right now I realized where from the failure occors:
The highlighted SetPoint Temperature as well as the faliure code: "T0
Error: Heater 1 fault: temperature rising much more slowly than the expected 1.7°C/sec" because of a faliure regarding Heating in General.
I measured all heaters, i connected new Temp.Sensors wirthout any effort.
So far Heater 0/1 and Heatbed are not working. Coud that be because of the Thermisor Fuse theat it is soldered to the Board is broken?Many thanks for your help!
Danijel -
Does the thermistor for that heater read correctly at room temperature?
Does the temperature reading for that heater rise at all when you turn it on for the first time, before the heater fault is reported?
Have you upgraded the firmware recently, or changed the power supply? If so, it may just be that you need to run M303 heater tuning on that heater.
@dc42 said in 3,3V yellow, 5V red, LED VIN blue Probe not working:
Hello dc42,
yes, the temperatur reading works fine on room temperature! No, when turning on the heater, the temperature doesn't rise at all......
The Heaters are PID tuned so far well.....strange really strage this failure!As well i Installed your last stable Firmware 3.2!
Tryed out again just to read the failure: "Error: M303: heater 0 reported error 'sensor open circuit' at start of auto tuning"
Many Thanks
Danijel
@Topenga said in 3,3V yellow, 5V red, LED VIN blue Probe not working:
sensor open circuit
Check your wiring.
Post your config.g and the results of M122
Maybe show a photo of your wiring at the board. -
Hello Phaedrux,
as requested:
18.1.2021, 01:24:55 M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996AL-K65SW-6J9F2-3SN6N-1B52X
Used output buffers: 3 of 24 (11 max)
Static ram: 23460
Dynamic ram: 73488 of which 44 recycled
Never used RAM 15088, free system stack 189 words
Tasks: NETWORK(ready,183) HEAT(blocked,311) MAIN(running,358) IDLE(ready,19)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:54 ago, cause: power up
Last software reset at 2021-01-16 13:26, reason: User, GCodes spinning, available RAM 14912, slot 0
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 29.3, current 36.4, max 36.5
Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-01-18 01:24:51
Cache data hit count 140372180
Slowest loop: 3.70ms; fastest: 0.20ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.9ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 79.60ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address 8c:aa:b5:d5:7d:0a
WiFi Vcc 3.39, reset reason Power up
WiFi flash size 4194304, free heap 20128
WiFi IP address 192.168.0.99
WiFi signal strength -60dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
; generated by RepRapFirmware Configuration Tool v3.2.0 on Wed Jan 06 2021 00:20:17 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"Dany's CR-10s Pro" ; set printer name; Network
M551 P"1945" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S1 ; enable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0 D2 S1 ; physical drive 0 goes forwards
M569 P1 D2 S0 ; physical drive 1 goes backwards
M569 P2 D2 S1 ; physical drive 2 goes forwards
M569 P3 D0 S1 ; physical drive 3 goes forwards
M350 X128 Y128 Z128 E16 I1 ; configure microstepping without interpolation
M92 X640.00 Y640.00 Z3200.00 E697.96 ; set steps per mm
M566 X2500.00 Y1100.00 Z200.00 E800.00 ; set maximum instantaneous speed changes (mm/min)
M203 X20000.00 Y20000.00 Z850.00 E5000.00 ; set maximum speeds (mm/min)
M201 X4000.00 Y1800.00 Z1000.00 E4000.00 ; set accelerations (mm/s^2)
M906 X2000 Y2000 Z800 E750 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y318 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"^!zprobe.in" H4.0 F250 T20000 ; set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y-40 Z2.5 ; set Z probe trigger value, offset and trigger height
;M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
M557 X2:270 Y10:305 S35 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bedheat" T1 Q10 ; create bed heater output on bedheat and map it to sensor 0
M307 H0 A258.8 C272.2 D2.1 B1 S0.85 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 A707.7 C227.9 D7.1 V24.3 B0 S0.75 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S300 ; set temperature limit for heater 1 to 300C; Fans
M106 P0 C"Part Cooling FAN0" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"Heatsink cooling FAN1" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 C"Drives cooling FAN2" S0 H-1 ; set fan 2 name and value. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F2 ; define tool 0
T0 ; select first tool -
The wiring should be o.k. because the board was working properly for some months.
Regarding Firmware.....after i realized that i have some trouble with the board i erased the memory and installed new firmware just to ensure that it is not to software issues.Many thanks in advance
Danijel
Well sensor open circuit would indicate it is not connected.
but sensor shows the correct room temperature?!?! As well conected a new Temp.Sensor to avoid any trouble with this...
Are you still getting that error?
@Phaedrux
unfortunately yes, still the same failure! But why are both Heaters blocked...... The strange...... Isn't it?
Is there a possibility that that a temp. Fuse is gone?Mfg T.
Possibly a blown PTC fuse on the thermistor, yes.
Do you see any damaged components on the board?
How did you wire up the PS-on? Do things improve if you remove the PS-on wiring?
Hello, the PS-On wiring I disconnected already and the same status as before, no changes. May you tell me where the PTC fuses are located on the board or even how they look like? Until now I was not able to locate any blown components on the board. Many thanks in advance
Best regards Danijel
You can see the schematics for your board version here: https://github.com/Duet3D/Duet-2-Hardware/tree/master/Duet2
Is this a genuine Duet or a clone? If Genuine, where and when was it purchased?
