@Phaedrux said in Rotary delta calibration not implemented?:
Why does it go from P0 to P2 then P5, but P5 still uses G10 commands with P2?
I switched to rrf firmware not long ago
You mean this?
I mean that during normal movement the printer moves correctly, during arc calibration you can see it on the video. it can be related to the offset of the tool and the sensor
I'm not exactly sure how the -Z offset on tool2 is going to have an effect. I'm not even really sure what the reasoning or intension is there.
You're using an IR sensor though, so you should have an XY offset configured for it in G31
G31 X0 Y0 Z33.385 P25
And the Z trigger height should be calibrated.
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
I would try simplifying your tool definitions to
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CAnd then select T0 at the end of config.g instead of T2
Then try G32 again.
https://github.com/Duet3D/RepRapFirmware/blob/dev/src/Movement/Kinematics/RotaryDeltaKinematics.cpp
221 bool RotaryDeltaKinematics::DoAutoCalibration(size_t numFactors, const RandomProbePointSet& probePoints, const StringRef& reply) 222 { 223 return true; // auto calibration not implemented yet 224 } 225 226 // Write the parameters that are set by auto calibration to a file, returning 227 true if success 228 bool RotaryDeltaKinematics::WriteCalibrationParameters(FileStore *f) const 229 { 230 return true; // auto calibration not implemented yet 231 }
I understand correctly that there is no calibration for rotary delta?
@Orang_ said in Rotary delta calibration not implemented?:
That is correct. The problem is that there are potentially many calibration variables for a rotary delta. For example, there are two pivot locations (like the tower position corrections for a linear delta), three upper arm lengths, three lower arm lengths, three pivot height corrections, three homing position corrections, and the delta radius. That's 18 parameters. It's unlikely the by probing a flat bed and measuring the height errors, it would be possible to calibrate all of these. However, if some of these are known to be accurate (for example, if all the arms are manufactured to precise lengths) then it may be possible to auto-calibrate the remaining parameters.
I can try adding auto calibration when I have time, but it might not give very good results.
@dc42 said in Rotary delta calibration not implemented?:
I can try adding auto calibration when I have time, but it might not give very good results.Thank you, I really like your firmware, if there are any changes with the calibration, please let me know, I would be happy to test it. Also there is not a big group of people who own similar printers I think they will also support it.
I'll just make @gloomyandy aware of this thread
@Orang_ on another note. Is there a good project for building one? Saw this one this week: https://www.youtube.com/watch?v=Tj1KAbq99dc
@PCR I have one of these https://www.youtube.com/watch?v=COUdIsoDgMw&ab_channel=AlexKorvinWorkshop
@jay_s_uk but smoothie doesn't work quite right.
@Orang_ who said anything about smoothieware?
@jay_s_uk I think he's saying smoothie (which runs on that thingiverse-link printer) doesn't work, so he's looking at Duet firmware.
The project specified in the link works on smoothie. but I reconfigured it to rrf
@Orang_ ah, ok. no problem
Do you know which parameters of your machine are likely to be accurate, and which need to be calibrated?
Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.
Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.M669 K10 U169.85 L320 R55.94 A-45:52 H432 X-60,Y60,Z180
U, L, - maybe accurate enough to measure;
R,H - within a small margin of error
A - it is difficult to measure without special tools
x y z - depends on the construction of the printer -
"Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers."is it possible in the future to add support for spi or i2c external ram?
or is it easier to buy a board with more memory? -
No.
Yes, such as the Duet 3 MB6HC or Duet 3 Mini.
