@dc42 said in Rotary delta calibration not implemented?:
That is correct. The problem is that there are potentially many calibration variables for a rotary delta. For example, there are two pivot locations (like the tower position corrections for a linear delta), three upper arm lengths, three lower arm lengths, three pivot height corrections, three homing position corrections, and the delta radius. That's 18 parameters. It's unlikely the by probing a flat bed and measuring the height errors, it would be possible to calibrate all of these. However, if some of these are known to be accurate (for example, if all the arms are manufactured to precise lengths) then it may be possible to auto-calibrate the remaining parameters.
I can try adding auto calibration when I have time, but it might not give very good results.Thank you, I really like your firmware, if there are any changes with the calibration, please let me know, I would be happy to test it. Also there is not a big group of people who own similar printers I think they will also support it.
I'll just make @gloomyandy aware of this thread
@Orang_ on another note. Is there a good project for building one? Saw this one this week: https://www.youtube.com/watch?v=Tj1KAbq99dc
@PCR I have one of these https://www.youtube.com/watch?v=COUdIsoDgMw&ab_channel=AlexKorvinWorkshop
@jay_s_uk but smoothie doesn't work quite right.
@Orang_ who said anything about smoothieware?
@jay_s_uk I think he's saying smoothie (which runs on that thingiverse-link printer) doesn't work, so he's looking at Duet firmware.
The project specified in the link works on smoothie. but I reconfigured it to rrf
@Orang_ ah, ok. no problem
@Orang_ said in Rotary delta calibration not implemented?:
Do you know which parameters of your machine are likely to be accurate, and which need to be calibrated?
Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.
Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers.M669 K10 U169.85 L320 R55.94 A-45:52 H432 X-60,Y60,Z180
U, L, - maybe accurate enough to measure;
R,H - within a small margin of error
A - it is difficult to measure without special tools
x y z - depends on the construction of the printer -
"Another issue may be available memory. The RAM needed to do the calculation goes up as the square of the number of parameters to be calibrated. Nine is OK because that's the maximum supported on linear delta printers."is it possible in the future to add support for spi or i2c external ram?
or is it easier to buy a board with more memory? -
No.
Yes, such as the Duet 3 MB6HC or Duet 3 Mini.
Why doesn't the G30 work in any way? I can't properly measure multiple points( -
Why doesn't the G30 work in any way? I can't properly measure multiple points(Because the auto calibration code has to be written to suit the kinematics, even though the basic principle will be the same as for a linear delta. We may also need a more sophisticated way of configuring which parameters are to be calibrated, rather than just having a # of parameters as we do for linear delta.
My guess is that the homing switch positions and delta radius are the most important to calibrate. Do you agree?
"My guess is that the homing switch positions and delta radius are the most important to calibrate. Do you agree?" - Yes, you're right. -
@dc42 you didn't do any "calibration"?
I don't have a rotary delta. I implemented the kinematics for a user who had one.
@dc42 And thank you for that.
