How do I get these messages away every 5sec
Most likely your slicer has inserted M117 commands in the GCode file that it generated. This is an option in some slicers.
@dc42 Not in the case of the gcode he uploaded.
no it is not an M117 in the entire Gode -
@Elko Do you have a daemon.g in your system directory? The only reason those messages can pop up is from a M117 code somewhere in your config.
No, it is not an M117 M118 in the entire Gode or in a system / file
Are you running a Duet 3 with attached single board computer? If that's the case, are you using a DSF plugin that could be generating the messages?
Do you have anything connected to the USB port of the Duet?
I now know where the "error" comes from
I connected Repetier to the Duet2 via WLAN
This will probably poll the data for 5 seconds when I start printing from there
Only for INFO I am fully satisfied with the DUET2 super thing -
@Elko said in How do I get these messages away every 5sec:
Only for INFO I am fully satisfied with the DUET2 super thingLooks like Repetier is sending those M117 command then! There may be an option in Repetier configuration not to generate them.
Thank you for your help
is not your problem !!
such a good support THANKS
