What types of move should the speed factor affect?
My vote would be speed up travel moves, leave retraction/unretraction, and z-hops. Ensure that maximum speeds from config can't be overrided.
Perhaps a parameter on M220. Default (with no parameters) as it stands with the option to change its behaviour with an optional parameter.
Of course that would mean the behaviour would have to be set in config.g if you wanted anything other than default and it would have to maintain that behaviour when M220 is sent without parameters to allow changes from DWC. -
@dc42 I agree. +1
Are moves during the tool change prcedure also travel moves? In that case it would be very useful not to include them, because a tool change using for example a T-lock is a speed sensible process.
I agree to @dc42 's proposal
@TC said in What types of move should the speed factor affect?:
Yes, they are. But I can exempt them separately.
So the following seem to be agreed:
- Printing moves (i.e. moves containing both XY movement and extrusion) should be affected by M220
- Extruder-only movements (retract/reprime) should not be affected by M220
- Movements within tool change files should not be affected
- Homing moves already are not affected
Not yet decided:
- Should all moves generated by any macro files (not just tool change files) be unaffected?
- Should non-extruding G1 moves be affected (i.e. travel moves when 3D printing)? For CNC machines and laser cutters, the answer is obviously yes.
I am leaning towards the following:
- Moves generated by commands in a macro file should not be affected
- Other travel moves should be affected
@dc42 I agree, that sounds like a good way to do it.
@dc42 I agree
I'd be tempted to exclude z only moves so z hop can be dialled-in, in a similar way to retraction and the speed up not effect it. Negligable effect on overall build time in most builds.
@DocTrucker said in What types of move should the speed factor affect?:
Perhaps M207 could be extended to include Z hop speed?
https://duet3d.dozuki.com/Wiki/Gcode#Section_M207_Set_retract_length
Does the speed factor override also override the acceleration rate or just the speeds after the acceleration phase? Because if it doesn't affect the acceleration rate, then short moves like Z hop are likely to be unaffected because they will either be accelerating or decelerating and never attain the set Z speed in any case.
@Phaedrux said in What types of move should the speed factor affect?:
Z-hop is generally so short that in practice it is acceleration-limited.
@deckingman said in What types of move should the speed factor affect?:
Acceleration and jerk are not affected by M220.
From the version 3.1.0 change list at https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md:
The speed factor (M220) is no longer applied to extruder-only moves or to movement commands in system or user macro files
Thanks for asking this thread. I don't know much about this speed factor. But I am interested and I would like to get some more details.
