Adapting 2 wire PT100 to 4 wire
@bearer Yes, it had just come to me that that was what you had done. So in actual fact, that may not be the solution. It could still be that it is wired the same as a two wire.
Never mind, I'll stick with it as a two wire, if I get discrepancies I'll search out a genuine four wire PT100
Thanks again
Keith
@kayjay said in Adapting 2 wire PT100 to 4 wire:
No, that photo is correct.
From the PT100 wiki page: https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
To connect a 4-wire PT100 sensor:
Connect the two wires that go to one end of the PT100 resistance element to pins 1 and 2 (it doesn't normally matter which wire in each pair goes to which terminal)
Connect the two wires that go to the other end of the PT100 resistance element to pins 3 and 4 -
@bearer Do you mind if I add your image to the PT100 wiki?
@Phaedrux I think that would be up to whomever I "stole" the pictures from (David/Wiki) to help illustrate.
But it that side of things is okay, then as far as I'm concerned use it as you see fit.
@phaedrux It may not be an accurate image, unless David can confirm that is how he connected his conjured 2/4 wire PT100.
It may well be correct but without confirmation it may lead someone up the wrong path so to speak.
Keith
Keith
Yes the image is accurate.
@phaedrux Is there actually a PT100 wiki or is it just part of another, bigger wiki. Just looked for it and can't see it. If there is one can you give me the link please?
Thanks very much
Keith -
@bearer said in Adapting 2 wire PT100 to 4 wire:
pretty much covered in the docs?
as to the why kelvin connection style is prefered is covered in detail here https://en.wikipedia.org/wiki/Four-terminal_sensing
You'll probably ignore this too, but...
@dc42 excellent David, that settles a whole heap of concerns .... made me a happy bunny too !
