Solved 3.5.0rc-1 corexy problem
I've just upgraded from 3.4.6 to 3.5.0rc-1 on my corexy. I've change M667 S1 to M669 S1 in config.g but the machine won't home.
Homing x only one stepper moves, and when homing y only the opposite stepper moves. This naturally causes the carriage to move diagonally and crash.
Could someone please point me in the right direction.
Many thanks
@Paddy said in 3.5.0rc-1 corexy problem:
Unless there is an issue with the beta firmware I am unaware of, you need to update that S to K:
M669 K1
From the documentation quote...............
"M667: Select CoreXY or related mode
This command is deprecated from RRF 2.03, and removed from RRF 3.5 and later. Use M669 instead."
If you're still having issues after that please post your full config.g and homing files as well as the results of sending M122 and M98 P"config.g"
@oozeBot You are quite correct. I did look up the gcode dictionary but was too busy looking at the number to notice the letter had changed.
Many thanks!!!!
