3.5 beta3 M291 S = 1 error if message box closed
I'm playing with M291, writing a lot of test messages to learn and test.
This macro throws an M292 error if I close the message box using DWC before the T delay times out. The error does not stop the macro from continuing to execute.
m291 s1 t5 P" Message 1: S=1, T=5. 10 second delay before the next message." R"S1 Testing (Close button)" g4 s10
firmware version?
@Phaedrux - sorry, that was sloppy of me.
HW MB6HC
RRF 3.5.0 beta 3
DWC - 3.5.0 beta 2Also, I tested this with and without the G4 command and it passes without that command.
undefined Phaedrux moved this topic from Gcode meta commands
Same behavior with DWC 3.5.0 beta.3
@mikeabuilder thanks, I've logged this as a potential bug to be investigated before the next beta.
This post is deleted!
