Idiot's Guide To Upgrading Duet Firmware
@gbartsch said in Idiot's Guide To Upgrading Duet Firmware:
@Phaedrux said in Idiot's Guide To Upgrading Duet Firmware:
... some things are probably a bit faster which can help quality as you don't want the print head hanging around oozing out plastic when it shouldn't be
The settings are definitely faster. I'll try increasing acceleration and maximum instantaneous speed changes as much as possible before the machine complains.
The maximum instantaneous speed settings are best left alone unless the machine stutters when printing circles.
@dc42 said in Idiot's Guide To Upgrading Duet Firmware:
Thank you.
Sorry, I mislead you. After upgrading I reduced some speeds and now want to try increasing them to as close to the defaults as possible.
My machine has heavy axes so bangs hard if the speeds are too high.
These are its current settings:
M566 X1000.00 Y1000.00 Z24.00 E3000.00 ; set maximum instantaneous speed changes (mm/min) M203 X30000.00 Y30000.00 Z900.00 E2700.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z200.00 E3000.00 ; set accelerations (mm/s^2)
Just a follow up; since the upgrade I've printed steadily and have yet to experience a disconnect from DWC. That appears to be fixed (crossing my fingers).
