Duet 2 Eth MakerGrear M2 3.3 > 3.42
Everything works right now, never very happy with corners, the old 8bit Rambo with Marlin was much better..
Going to upgrade to 3.42, will I break anything? Also, can someone point me to the Proper Doc for the Duet 2, the firmware doc is a bit over whelming and unclear to the user who has not touched this in a year..
Thanks! -
@airscapes the documentation is all at https://docs.duet3d.com/.
You could install version 3.3 of the ReleaseMgr plugin from https://github.com/MintyTrebor/ReleaseMgr/releases/tag/0.01.14Beta to check what has changed.
@dc42 Link to how to install a plugin please?
@airscapes said in Duet 2 Eth MakerGrear M2 3.3 > 3.42:
To install the Input Shaping plugin, download the latest release version for your RepRapFirmware version from the Duet3D Github repository as a .zip file, without unpacking it, and upload it using the Upload&Start button on DWC without unpacking the file first. After this, you should see the Plugins category with a new Input Shaping item in the main menu on the left:
That's the directions for the input shaping plugin, but the steps are the same for other plugins. Download the zip and upload the zip.
@Phaedrux Thanks and Merry Christmas!
