scaling and bed seize trubel
i am having a lots of problems with prints coming out in the wrong shape and the bed axis limits seems wrong but i can move the head all over the bed now butt stil the prints are miss shaped. are there any obvious mistakes
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jan 08 2022 17:50:57 GMT+0100 (Midden-Europese standaardtijd); General preferences
M550 P"Modix Big-60" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards. X-Axis.
M569 P1 S0 ; physical drive 1 goes forwards. Y-Axis.
M569 P2 S0 ; physical drive 2 goes forwards. Z-Axis.
M569 P3 S1 ; physical drive 3 goes forwards. E0-Extruder p3 s1.
M584 X0 Y1 Z2 E4 ; set drive mapping E3=E0
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z800.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z4000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z300.00 E250.00 ; set accelerations (mm/s^2)
M906 X1800 Y1800 Z2400 E1000 I40 ; set motor currents (mA) and motor idle factor in percent
M208 X-300 Y-100 Z0 S1 ; set axis minima
M208 X300 Y1200 Z610 S0 ; set axis maxima
;M208 X0:600 Y0:600 Z-1:660 ; 101222 Set axis minima and maxima; Endstops
M574 X1 S1 P"!^xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"!^ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S2 ; Define Z to use BLTouch probe;M579 X1.0 Y1.0 Z1.0
; Z-Probe BLTouch on Duet WiFi
M307 H7 A-1 C-1 D-1 ; Disable heater 7 for BLTouch
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H15 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds
M280 P0 S10 ; send control signal to BLTouch through servo/gpio 0"; Heaters
;M308 S0 T500000 B4723 C1.196220e-7 ; Set thermistor + ADC parameters for heater 1 ; configure sensor 1 as thermistor on pin e0temp
;M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
M308 S1 P"e0temp" Y"thermistor" A"e0_heat" T500000 B4723 C1.196220e-7 ;Slicer Engineering 405°C thermistor
;M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1
M307 H1 R2.662 C145.3:136.3 D5.08 S1.00 V24.1
;M307 H1 R2.185 C151.4:140.7 D4.45 S1.00 V24.1
;M307 H1 R2.247 C148.4:132.8 D5.56 S1.00 V24.1 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Miscellaneous
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Can you show some photo examples of what you mean? It's not clear what problem you're having.
@Phaedrux
the prints i tried to make we're meant to be circular, instead they came out oval. so i tried scaling the axis but later i figured out the Y axis didn't fully cover the bed. the Y axis was scaled properly but the same as the X axis but it could only do it well if i said the bed was 3~ times as long.I don't know whether this is a software of hardware problem, 'cos we've already replaced the motors, and now we're trying to remove the mistakes from the config.g
@3dorbit said in scaling and bed seize trubel:
Do you have motor pulleys with the same number of teeth on the X and Y axis? Check, and if not, adjust M92.
Or are either of them loose? A loose pulley will also cause oval prints.
If you command each axis to move 100mm, does it actually move 100mm?Ian
thank you @droftarts , the Y axis indeed had the wrong amount of teeth
