CPAP/Centrifugal Blower
I'm trying to setup a WS7040 centrifugal blower and 24v driver on my Duet3 + RPI4.
Before I installed it I had it connected with a 24v power supply and used my bench top power supply with + connected to VSR and GND to GND. The fan would turn on when I would apply .6v or more.
Now connected to the duet by the attached wiring and configured as
M950 F0 C"0.out9" Q2000 M106 P0 C"CPAP Fan1" S0 B0.1 H-1
I've also tried a number of values between Q500 and Q65535.
The issue is the turbine won't turn on until the fan slider is at 15%. While troubleshooting I used a volt meter and probed the VSR pin and the 24v - on the driver board with the fan set to 5% and the turbine started to spin. Do I need to invert 0.out9 or what am I missing?
Or do I need to purchase a frequency to voltage converter like this
I have the same too.
I haven't inverted anything either and only use 15% or more in the slicer.But if there is a possibility that it starts under 15% I would be interested in it.
@heartleander81 @dhusolo fans generally have a minimum rpm (and hence PWM) that they can turn at.
I have the same type of CPAP, I can't go under 15% too, the board seems to have a minimum voltage startup. @dhusolo
Maybe you can configure in RRF 0% for the slicer matching 15% for the FAN to keep easier slicer setting to avoid false 0% with 10% set in the slicer. @dc42 ?
If someone found the CPAP board schematics I could investigate deeply (I'm electronic engineer)
@jackantubis if you set the L parameter in the M106 command to 0.15 then I think a command for 10% PWM should be translated to 15% PWM.
@dc42 I was hoping to figure out a way to not have to set min/max speed. Would it be possible to use an open extruder heater port?
I have connected to 5V PWM a servo for the Klicky Probe, is there any way to connect the CPAP differently and configure it as a fan?
@gringo most servos accept a 3.3V control signal, so you can probably connect that servo to a PWM-capable IO port instead.
Thank you . I will try it.
Has anyone figured out a way to read the fan rpm?
@Reine I've looked at the datasheet for the controller board and it doesn't appear to provide a tacho output.
I guess you could use an opto isolator with a parallel diode and series resistor, connected across one of the motor phases, and connect the opto isolator output to an input on the Duet.
Simone has already done a write up on how to set them up.
https://www.modernmakes.ca/3d-printing/cpap-fan-guide
There is a speed output pin which is pin PG.
try to set the minimo speed with L parameter of M106 and a blip to start at full
M106 P0 C"CPAP Fan1" S0 L.15 B.5 X1 H-1
You could also limite max speed just in case it blows too much with the X param
Did you guys end up getting the speed signal to work or did you abandon it?
@apak I have it setup like this, without X last few % didn't do anything.
M106 P0 C"CPAP Fan" S0 B0.1 H-1 L33 X214
I found the single 5V pwm output limiting, plus to get the most precise control, an analog 5v fed to the CPAP blower driver board is most accurate. Tried a few ways to do that and settled on this board https://www.amazon.com/dp/B079BH3SHX?psc=1&ref=ppx_yo2ov_dt_b_product_details -- it's powered by 24v, will take the pwm output of a regular fan output and create a clean 0-5v analog output. If you run it at 100-200hz you can get the low end to be around .5v, and that's as slow as the CPAP blower can go. I can go the full spectrum and have perfect output control. Not sure of another source for these boards, but I will use them for duet and for klipper configs since they're simple and the best part is the fan control is super accurate.
