Heated chamber faults when opening door
I've recently upgraded to 3.4.0 and am having trouble with my heated chamber config. At first my M307 parameters didn't work at all, I would get a "heating to slowly" fault after a few seconds. I ran auto tune (which took 5+ hours to complete for my heavily insulated chamber...) and changed to the new M307 parameters. Those seem to work great, but have one major problem. If I open the door to get a better look at the print (or whatever) the heater faults in a few seconds. It's impressive that it can be modeled so accurately, but I need a way to loosen the restrictions for the chamber heater.
How can I adjust the settings so that it wont be so particular about the temp control? The chamber heater really doesn't need to be so accurate or fault for relatively small inconsistencies.
Thanks!
I suppose you could add a switch to the door so that when you open it the chamber heater is turned off and re-enabled when it's closed via conditional gcode.
@cpirius you can use the M570 command to increase the permitted temperature excursion. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m570-configure-heater-fault-detection. Or do as @Phaedrux suggests.
