CoreXY update to 3.3 gone Wrong
Long time user of Duet Wifi on my CoreXY, but getting updated to latest firmware is a nightmare. Here's where I'm at. 3.3 is installed, but things do not work proper. From an un-homed position, I hit the homeall button in DWC and all axes move slightly(a few mm), then it shows that all axes ARE homed without any of the end stop switches being triggered. I've had a friend with same setup as mine look over my stuff and like me, he says that should work, but it doesn't. Here are my config.g and homing files that were generated by the configurator. Desperately needing some help...............................................;
General preferences
M550 P"CoreXY 1" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S0 ; physical drive 2 goes forwards
M92 X80.00 Y80.00 Z400.00 E837.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z800.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y185 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:185 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
Homeall:
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H1 X-325 Y190 F3000 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-325 ; home X axis
G1 H1 Y190 ; home Y axis
G1 X5 Y-5 F6000 ; go back a few mm
G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y190 ; then move slowly to Y axis endstop
G1 H1 Z-305 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioninghomex.g:
; homex.g
; called to home the X axis
G1 H1 X-325 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioningHomey.g:
; homey.g
; called to home the Y axis
G1 H1 Y190 F3000 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F6000 ; go back a few mm
G1 H1 Y190 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioninghomez.g:
; homez.g
; called to home the Z axis
G1 H1 Z-305 F3000 ; move Z down until the endstop is triggered
;G90 ; absolute positioningLet me know if any more info is needed. THANKS!
@gbusy24 what type of endstop switches are you using? If they are normally open switches, three-wire switches or Hall sensors then you probably need to invert the pin polarity in your M574 commands.
@fcwilt, It was one of the later 2.? FW versions, but it's been a while since I started this update and can't quite remember the exact one.
@dc42, I have mechanical end stop switches and I will give your suggestion a try. Had considered that might be my issue. I'll let you know how it goes. Thanks.
@gbusy24 said in CoreXY update to 3.3 gone Wrong:
Did you remember to first update to 3.0 before doing the update to 3.3?
@fcwilt Yes.
@fcwilt Yes.
The usual cause of what you are seeing when homing is that the endstop switches are indicating they are active when they are not. The G1 H1 moves never happen because the endstop reports active and the only moves that happen are the "back off" moves between the pairs of G1 H1 moves.
@fcwilt And I go about correcting this how?
@gbusy24 Your current config for endstops:
; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
See https://duet3d.dozuki.com/Wiki/M574. Test switches with M119. You probably want
; Endstops M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
ie Add
to each endstop pin definition, to invert the input.Ian
@droftarts Aha! Let me try that. Thanks.
@droftarts Fabulous! that did it. Thanks
