@diy-o-sphere A friend helped me find the problem. Thanks for your help.
Best posts made by GBusy24
RE: Y Axis Homing Issues CoreXY
RE: Can't get connected to DWC setting up new Duet 2 Wifi
@phaedrux, This site is flagging my copy and paste of the M122 Diagnostics report as spam and will not let me post it. How do I get around that?
RE: Extruder motor not working correctly after update
@dc42 Hi, I just saw your message and ran the command. E-thing seems good to go. Here's the response: "M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
I've come to terms that this smaller stepper needs higher current than normal sized steppers. I'm okay with that. I've used this motor for years on my setup and haven't had any problems. I am going to show it a lil' love tho with a nice heatsink that arrives tomorrow -
Trying to set up my second Duet 2 Wifi. Bought my first over 5 years ago and I've forgotten pretty much e-thing. My new board shows it's running ver. 2.05.1 firmware when sending m115 thru Yat. I'm able to save my ssid and PW thru M587, but when I send M552 S1, it's telling me no networks found. Question: Do I need to update the FW, duet wifi server and DWC by pulling the card and putting it in my computer to do so? I appreciate any help.
RE: Weird Issue with Duet Wifi Wifi connection
@günter-jibben Wow, Thanks! Didn't know this info was out there.
@phaedrux That did I
it! Thank you -
RE: Bed heater faulting out after RRF 3.0 and later update
@jay_s_uk Thanks for your help. Everything is sorted out and working proper now. No more faulting out.
RE: CoreXY update to 3.3 gone Wrong
@droftarts Fabulous! that did it. Thanks
Latest posts made by GBusy24
RE: 2 NEW DUET 2 WIFI's W/EXTERNAL ANTENNA WILL NOT CONNECT
@Phaedrux The answer is yes to all 3 of your questions. It's morning here and I'll try that when I get home from work.
@jay_s_uk I set my network ...........it remembers it and M587 confirms. I send M552 S1 and get 'No known networks found".
M587 S"Greg's WIFI" P"**********"
M587
Remembered networks:
Gregs WIFI IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
TNCAPF318D9 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
ok
M552 S1
ok
Error: WiFi module reported: no known networks found -
@jay_s_uk I've now switched out the antennas, but still in same condition. No connection. Scratching my head. Here's a pic of the board. Is it a mistake to wire everything up before connecting? I know I've done this before successfully.20250415_191452.jpg
@jay_s_uk I will say that when working with the other board the green light on the Wi-Fi module would blink constantly where I get nothing out of this current board I'm working with
@jay_s_uk okay, but who will sell me just the antenna? I have two because I have two new boards. Maybe I should try the other antenna off of The Other Board
@jay_s_uk I'm really confident that the antenna is connected correctly but I will mention that it is not mounted it is just laying near the board
@jay_s_uk may I ask what you would be looking for on the board and maybe I can help her memory. It is one of the newer boards with the external Wi-Fi antenna
@jay_s_uk unfortunately, I'm at work right now
@Phaedrux one of my posts to you last night seems to be deleted or at least it's grayed out and I don't know if you saw it so I'm going to reshare the link I had in the post. Here it is...M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2024-09-18 11:25:32
ok
M587
ok
M552 S0
ok
M552 S1
ok
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.3 (2024-09-18 11:25:32) running on Duet WiFi 1.02 or later
Board ID: 0JD6M-99APT-NU4SN-6J9F4-3SD6K-14PTL
Used output buffers: 1 of 26 (1 max)
=== RTOS ===
Static ram: 23376
Dynamic ram: 72792 of which 0 recycled
Never used RAM 17308, free system stack 194 words
Tasks: NETWORK(1,ready,7.0%,339) HEAT(3,nWait 5,0.0%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,92.9%,501) IDLE(0,ready,0.1%,29), total 100.0%
Owned mutexes: USB(MAIN)
Last reset 00:20:56 ago, cause: power up
Last software reset details not available
Error status: 0x00
MCU temperature: min 25.7, current 30.8, max 31.9
Supply voltage: min 0.2, current 1.4, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
Events: 0 queued, 0 completed
Driver 0: ok, SG min n/a
Driver 1: ok, SG min n/a
Driver 2: ok, SG min n/a
Driver 3: ok, SG min n/a
Driver 4: ok, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 1970-01-01 00:00:00
Cache data hit count 4294967295
Slowest loop: 99.91ms; fastest: 0.14ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
=== Storage ===
Free file entries: 10
SD card longest read time 3.2ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
no step interrupt scheduled
Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
=== DDARing 0 ===
Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
Movement locks held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is ready with "M122" in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Q0 segments left 0
Code queue 0 is empty
=== Network ===
Slowest loop: 0.73ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 0 of 8
=== WiFi ===
Interface state: changingMode
Module is idle
Failed messages: pending 0, notrdy 0, noresp 0
Failed to get WiFi status
ok
Error: failed to retrieve WiFi status message: bad reply format version
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
WiFi module is idle
