RRF Update to 3.3 just killed my FW
@phaedrux Attached.
In the meantime the PanelDue is a 5.0i but it does not seem to want to update via the Duet. It's 3 years old. Think I'll need to remove it from it's containment and hit a resent button?M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917DA-G4MS8-6JKD0-3S06N-K9TVB
Used output buffers: 3 of 24 (12 max)
Static ram: 23876
Dynamic ram: 75052 of which 0 recycled
Never used RAM 15488, free system stack 184 words
Tasks: NETWORK(ready,14.4%,244) HEAT(delaying,0.0%,326) Move(notifyWait,0.1%,364) MAIN(running,85.2%,417) IDLE(ready,0.4%,29), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:04:26 ago, cause: power up
Last software reset at 2022-01-31 19:16, reason: StuckInSpinLoop, GCodes spinning, available RAM 12280, slot 0
Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x2000254c Task MAIN Freestk 900 ok
Stack: 004534c9 00455180 810f0000 00000000 3f000000 369dc3a0 3edbc06f 3331bb4c 40000000 b5ddd98d 388ab355 bb360b61 3e2aaaab 3f800000 00000000 00000000 4354c416 00000000 00000000 60000010 004534c1 200080c8 00408da7 00000000 200182c8 20004c8c 0041872b
Error status: 0x00
Step timer max interval 0
MCU temperature: min 37.4, current 39.2, max 39.6
Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2022-01-31 19:26:17
Slowest loop: 7.69ms; fastest: 0.17ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.1ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 182.04ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.26
WiFi MAC address bc:dd:c2:89:a2:9b
WiFi Vcc 3.38, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24160
WiFi IP address 192.168.1.92
WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
@andy-cohen said in RRF Update to 3.3 just killed my FW:
I think you'll need to update it's firmware via usb as well so that it can communicate with RRF3 as well. I think the latest firmware is 3.4 for the paneldue. I think once you have it up to date with the firmware you'll actually be able to update it via DWC in the future.
https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update#Section_Firmware_update_via_USB
It looks like your main firmware and wifi firmware are up to date now. Can you confirm that DWC is also at 3.3?
@phaedrux Right. I'm already there.
Bossa does not work in the latest MacOS.
I'm forced to find a ... PC.BTW where do I find the DWC version?
@andy-cohen to get Bossa working on macOS, see this thread: https://forum.duet3d.com/topic/11445/
Find DWC version in DWC on system page, general tab https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_General_tab
@droftarts said in RRF Update to 3.3 just killed my FW:
DWC is at 3.3.
Found a PC and updated the PanelDue. The update worked but it does not see the tools nor does it operate anything. My bet is I have to add a line in the config... right? -
@andy-cohen Yup!
All seems to be working fine for now.
I'm really not looking forward to updating my Toolchanger! -
This post is deleted! -
@andy-cohen This update FUBARED my machine. WHY was SO much changed?
Now I cannot control the tool from the PanelDue. I get constant messages about commands that no longer work WTF!
The tool definition makes no sense at all to me!
I cannot see how the Extruder is associated with the tool AT ALL!!! -
M563 P1 ; Define tool 1
This tool has no extruder or heater assigned to it. Perhaps that's your issue? You didn't mention which tool you're trying to control.
Can you share a recent config.g?
PanelDue is up to date now? DWC is at 3.3 as well?
@phaedrux When I try to retract at the hotend from the panel it does nothing. Then the panel becomes unresponsive. I cannot believe how frustrating this is! Why so many changes?
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 31 2022 16:37:49 GMT-0800 (PST); General preferences
M550 P"My Printer" ; set printer name; Network
M550 P"CloneDuet" ; Set machine name
M551 P"adc238" ; Set password
M552 S1 ; Enable network
;M587 S"ATT642_EXT" P"4269605351" ; Configure access point. You can delete this line once connected
M587 S"ATT642" P"4269605351" ; Configure access point. You can delete this line once connectedM575 P1 B57600 S1 ;Paneldue
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
M669 K1 ; switch to CoreXY mode
M569 P2 S0 ; physical drive 2 goes forwards
M92 X88.57 Y88.57 Z400.00 E125.459271 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y195 Z210 S0 ; set axis maxima; Endstops
M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z1 S1 P"!zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X10:300 Y-16.0:195 S20 ; define mesh grid; Heaters
;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
M307 H0 B0 R0.219 C409.3 D5.09 S1.00 V23.7 ;From auto tune
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M307 H1 B0 R2.422 C201.2 D10.87 S1.00 V24.0 ;From Auto tune
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P1 X35 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
How many tools do you have? one or two?
Can you share your config from RRF2?I understand you're frustrated, but it's really not as devastating and you're making it out to be. Answer my questions and we'll get you back up and running.
The upgrade isn't forced and you can go back if you wish.
@phaedrux I have one. The code there is taken from the old config. When I put in what came out of the web app it does not work at all.
This is what was generated by the web app:
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C -
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0CIf you only have a single tool remove this section for tool1 then.
Does the extruder move when at temp?
Can you be more specific? What do the messages actually say? What commands?
Can you confirm that the PanelDue is up to date now by checking it's version on the setup page?
@phaedrux OK... I will rem those lines out.
The messages were as follows:
"Error Tool 0 not found"
"Error: Attempting to Extrude with no tool selected"
There were more but I lost them. -
@phaedrux I remmed out the lines and rebooted.
The PanelDue shows the extruder icon with a Zero next to it(it used to show a "1").
I set the temp and heat it up. I select the Icon button so it's highlighted and I then go to the button to extrude some filament and hit extrude and nothing happens -
Can you add
T0
to the end of your config.g so that the first tool is selected at startup? -
Can you send M98 P"config.g" and post the results?
@phaedrux said in RRF Update to 3.3 just killed my FW:
The T0 on the last line is a good idea. I have that on my TC config. Trying now.Date Event
2/1/2022, 6:51:28 PM M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled -
@phaedrux So it will now extrude on command using the Extrude dialog on the PanelDue. Why it would not manually select IO have no clue, but the highlight on the button went on when selected.
BTW I was able to capture the message that flys by. Turns out it repeats over and over...
"Warning: Obsolete use of S parameter on G1 command. Use H parameter instead"
Looks like a good clue! -
@phaedrux It's not coming from my start gcode as far as I can see...?
; ****DuetClone start.gcode ****
G28 ; home all axes
;G29 S1 ; Use the Z offset Mesh Map on the SD card
M140 S[bed0_temperature] ; Heat buildplateG1 X0 Y0 Z10 F9000 ; Move to wait position off table
M190 S[bed0_temperature] ; Stabilize bed temperature
G10 P0 S[extruder0_temperature] R[extruder0_temperature] ; Set tool 0 operating and standby temperatures
M109 S[extruder0_temperature] ; set extruder temp and wait
start of purge line
G1 X40 Y5.5 Z0.2 F600.000 ; Extruder Prime Dry Move
G1 X250 Y5.5 Z0.2 F600.000 E25.000 ; Extruder Prime Start
G92 E0 ; Zero extruders
; **** end of start.gcode ****
