RRF Update to 3.3 just killed my FW
@andy-cohen said in RRF Update to 3.3 just killed my FW:
"Warning: Obsolete use of S parameter on G1 command. Use H parameter instead"
It's your homing files.
@phaedrux OK... so I swap out the S with an H?
Seriously... that was changed?
I'm finally printing...
But...
the message seems to be popping up from the G1 commands generated by my slicer; Simplify3D. I do not see anything in S3D's setup which can change that. -
@andy-cohen I might be incorrect on that. The messages have stopped. It could have all come from the homing scripts.
So...
Where else can I expect changes???
This was the "easy" machine to update. I did this update as a "practice" for the update of my Toolchanger. -
@andy-cohen The messages were from the homing scripts.
Just printed a perfect cal cube. Thanks for all your help and especially your patience. I'll be sure to do a shout out to you (well... your online handle at least) on the podcast. Without your help (and the others here) I do not think I would have figured it out. -
The S/H change was to become compatible with laser engraving software which uses G1 S for laser power. Easier to change the homing modifier than try to convince laser software makers to change their gcode.
You can find an example tool changer config for RRF3 here
https://github.com/Duet3D/RRF-machine-config-files/tree/master/E3D_Tool_Changer/dc42-duet3-centreZero-2Titan-2HemeraYou can get a handle on what's changed here: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
