Dual IR Z probes.
I'll try to keep the explanation as simple as possible, but I'm trying to flesh out the concept for an IDEX COREXY machine.
My concept calls for two separate X rails, one for the X axis, and another for the U axis.
These two rails would introduce the chance for variation between them in Z, but ideally I could compensate for that with a second Z probe attached to the U carriage.
Is it possible to store a height map that is specific to each tool? And more importantly, call them up independently during a print when there's a tool change?
@terbospaghetti
I'm sure the Z-difference between two independent carriages will boil down to a constant offset. (both running on the same Y-rails)
So there'd be no need for a second heightmap.
IMHO you'd have to unload heightmap X, rename both heightmaps and load heightmap U, if you still think you'd need two maps*if you can use two IR probes is another story
@terbospaghetti yes you can use two Z probes, generate two height maps and load the correct one in the tpost file.
