Firmware upload Duet 3 6HC
Hello
I Have the Duet 3 6HC with a raspberry pi in SBC mode. Everything worked well until i accidently erased the firmware on my duet.For some reason I can't upload a new Firmware. I tried to flash it with the raspberry over ssh. I used Bossa but the responce was "Unkwown device at tty/ACM0". After that i tried to install Bossa on my pc. When I connected the duet to my PC, it's recognised as "Bossa Programming Port(COM5)". I can read the flash with the programm but i can't write anything. The Bossa programm gets stuck whenever i try to write anything. The responce that i get is "Writing Page 0 (0%)". No matter how long i leave the programm running, it won't progress. i even tried diffrent versions of the "Duet3Firmware_MB6HC.bin".
How can upload a Firmware again and acces my printer with the DWC?PS: sorry I couldn't change the topic to FIrmware installation.
Can you give bossa a try again?
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_2
How did you manage to erase the firmware accidentally? Did you remove the erase jumper?
You'll need a good quality USB cable. Try different cables and ports.
@printoverse said in Firmware upload Duet 3 6HC:
When flashing firmware, the microcontroller on the 6HC is unfortunately rather fussy about the type of USB cable and USB port. So try a different USB cable, and/or a different USB port on the PC.
This post is deleted!
