Duet 3 6HC stuttering and not using up filament during print
Hi all,
I am running first prints with a newly built printer.
For some reason I am running into an issue, where the printer is not moving smoothly and is not using filament.
- not moving smoothly is especially visible during circles
- not using filament, the extruder stepper is changing from extrusion to retract but is averaging at ~0
Giving the same gcode several tries will eventually result in a working one.
I am trying to run it down with one routine- power up printer
- goto "Jobs"
- select/start print
- within gcode:
-- heat up of bed / tool
-- G32 for homing and tramming
From M122 (see below) i am wondering, if:
=== CAN === Messages queued 1976, send timeouts 0, received 4518, lost 0, longest wait 2ms for reply
is ok, due to the messages in queue?
Maybe, bad CAN connection?Thx in advance.
System Details:
Board: Duet 3 MB6HC (MB6HC) DSF Version: 3.2.2 Firmware: RepRapFirmware for Duet 3 MB6HC 3.2.2 (2021-02-11) RPI 4 SBC, updates last checked today Duet TOOL1LC firmware version 3.2 (2021-01-05)
M122:
M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S8-6J9D4-3SN6M-TU0UG Used output buffers: 4 of 40 (10 max) === RTOS === Static ram: 149788 Dynamic ram: 62836 of which 88 recycled Never used RAM 146120, free system stack 128 words Tasks: Linux(ready,77) HEAT(blocked,297) CanReceiv(blocked,834) CanSender(blocked,344) CanClock(blocked,352) TMC(blocked,17) MAIN(running,720) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:06:09 ago, cause: software Last software reset at 2021-04-27 20:51, reason: User, Platform spinning, available RAM 146536, slot 1 Software reset code 0x0000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 40.0, current 41.1, max 42.1 Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 65938, ok, reads 37397, writes 17 timeouts 0, SG min/max 0/1023 Driver 1: position 1629, standstill, reads 37397, writes 17 timeouts 0, SG min/max 0/1023 Driver 2: position 840, standstill, reads 37399, writes 17 timeouts 0, SG min/max 0/1023 Driver 3: position 0, standstill, reads 37399, writes 17 timeouts 0, SG min/max 0/439 Driver 4: position 0, standstill, reads 37399, writes 17 timeouts 0, SG min/max 0/476 Driver 5: position 0, standstill, reads 37405, writes 11 timeouts 0, SG min/max 0/0 Date/time: 2021-04-27 20:57:17 Slowest loop: 183.64ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 77883ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 1148, completed moves 1141, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 X198.794006 Y186.348999 E0.581140" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 1976, send timeouts 0, received 4518, lost 0, longest wait 2ms for reply type 6049, free buffers 48 === SBC interface === State: 4, failed transfers: 0 Last transfer: 3ms ago RX/TX seq numbers: 13507/13507 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2c85c Buffer RX/TX: 1296/2808-0 === Duet Control Server === Duet Control Server v3.2.2 File: Buffered code: G1 X198.794 Y186.349 E0.58114 Buffered code: G1 X199.36 Y186.349 E0.01883 Buffered code: G1 X211.149 Y198.138 E0.55452 Buffered code: G1 X211.149 Y197.572 E0.01883 Buffered code: G1 X199.925 Y186.349 E0.52792 Buffered code: G1 X200.491 Y186.349 E0.01883 Buffered code: G1 X211.149 Y197.007 E0.50132 Buffered code: G1 X211.149 Y196.441 E0.01883 Buffered code: G1 X201.057 Y186.349 E0.4747 Buffered code: G1 X201.623 Y186.349 E0.01883 Buffered code: G1 X211.149 Y195.875 E0.44807 Buffered code: G1 X211.149 Y195.309 E0.01883 Buffered code: G1 X202.188 Y186.349 E0.42147 Buffered code: G1 X202.754 Y186.349 E0.01883 Buffered code: G1 X211.149 Y194.744 E0.39488 Buffered code: G1 X211.149 Y194.178 E0.01883 Buffered code: G1 X203.32 Y186.349 E0.36825 Buffered code: G1 X203.885 Y186.349 E0.01879 Buffered code: G1 X211.149 Y193.612 E0.34165 Buffered code: G1 X211.149 Y193.047 E0.01879 Buffered code: G1 X204.451 Y186.349 E0.31505 Buffered code: G1 X205.017 Y186.349 E0.01883 Buffered code: G1 X211.149 Y192.481 E0.28843 Buffered code: G1 X211.149 Y191.915 E0.01883 Buffered code: G1 X205.582 Y186.349 E0.26183 Buffered code: G1 X206.148 Y186.349 E0.01883 Buffered code: G1 X211.149 Y191.35 E0.23523 Buffered code: G1 X211.149 Y190.784 E0.01883 Buffered code: G1 X206.714 Y186.349 E0.20861 Buffered code: G1 X207.279 Y186.349 E0.01879 Buffered code: G1 X211.149 Y190.218 E0.18201 Buffered code: G1 X211.149 Y189.653 E0.01879 ==> 1520 bytes Code buffer space: 1288 Configured SPI speed: 8000000 Hz Full transfers per second: 36.75 Maximum length of RX/TX data transfers: 4454/1552 File /opt/dsf/sd/gcodes/TXXPRO_CHEPCalibrationCube.gcode is selected, processing
M122 B20
M122 B20 Diagnostics for board 20: Duet TOOL1LC firmware version 3.2 (2021-01-05) Bootloader ID: not available Never used RAM 4040, free system stack 50 words HEAT 86 CanAsync 85 CanRecv 83 TMC 54 MAIN 216 AIN 64 Last reset 00:44:57 ago, cause: software Last software reset data not available Driver 0: position -9956, 430.1 steps/mm, ok, SG min/max 0/16, read errors 0, write errors 1, ifcnt 34, reads 37840, writes 21, timeouts 0, DMA errors 0 Moves scheduled 7866, completed 7865, in progress 1, hiccups 0 Next step interrupt due in 2517 ticks, enabled VIN: 23.9V MCU temperature: min 41.2C, current 51.3C, max 51.5C Ticks since heat task active 211, ADC conversions started 2686474, completed 2686473, timed out 0 Last sensors broadcast 0x00000002 found 1 215 ticks ago, loop time 0 CAN messages queued 32597, send timeouts 0, received 32342, lost 0, free buffers 36
Screenshot DWC:
@marshal said in Duet 3 6HC stuttering and not using up filament during print:
Looks like your tool board firmware is out of sync with the mainboard. Try sending M997 B20 to initiate the firmware update on the tool board.
Are you set to relative extrusion in your slicer?
@phaedrux: my bad, i have changed the LC1 due to a bad resitstor, but didn't confirm the firmware ...
M122 B20 Diagnostics for board 20: Duet TOOL1LC firmware version 3.2.2 (2021-02-11) Bootloader ID: not available Never used RAM 4108, free system stack 94 words HEAT 90 CanAsync 89 CanRecv 83 TMC 56 MAIN 216 AIN 64 Last reset 00:00:16 ago, cause: software Last software reset data not available Driver 0: position 0, 430.1 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 23, reads 8021, writes 11, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.3V MCU temperature: min 39.1C, current 39.2C, max 39.3C Ticks since heat task active 97, ADC conversions started 16060, completed 16059, timed out 0 Last sensors broadcast 0x00000002 found 1 101 ticks ago, loop time 0 CAN messages queued 122, send timeouts 0, received 149, lost 0, free buffers 36
I will test soon.
@JamesM: M83 is called before from job to run.
;FLAVOR:RepRap ;TIME:1876 ;Filament used: 0.562977m ;Layer height: 0.2 ;MINX:177.567 ;MINY:181.574 ;MINZ:0.125 ;MAXX:225.933 ;MAXY:211.149 ;MAXZ:52.925 ;Generated with Cura_SteamEngine 4.9.0 T0 M190 S70 M104 S240 M109 S240 M82 ;absolute extrusion mode G32 M83 ;relative extrusion mode G1 F2400 E-2 ;LAYER_COUNT:265 ;LAYER:0 M107 G0 F1800 X180.77 Y185.898 Z0.125 ;TYPE:SKIRT G1 F2400 E2 G1 F1200 X181.549 Y185.164 E0.04005 G1 X181.772 Y184.974 E0.01096 . . .
@marshal you may wish to upgrade to firmware 3.3beta3. This addresses issues with using CAN-connected expansion boards when there are a lot of very small movements.
i continued testing this evening,
- Upgrading Toolboard to 3.2.2 (all system 3.2.2) --> issue remains
- Upgrading all to 3.3beta3 --> issue remains
Currently i am using a 3DTouch (BLTouch clone), with 3.3beta3 i had some events, where probe was not deployed, or was triggered before touching bed. Which seemed more an issue of the sensor after the previous "touch" than anything else.
I have extended retractprobe.g
to:
M280 P10 S90 G4 P200 M280 P10 S160
I have done 3 test prints in a row now, no issue yet.
Maybe the sensor was putting noise on Toolboar.io0.in?More prints will tell if it is fixed like this. Maybe a BLTouch will replace the 3DTouch soon.
