M300 Sound is almost inaudible ?
Does your PanelDue enclosure include holes for the sound from the piezo buzzer to pass through?
AFAIR the piezo buzzer is most sensitive around 4kHz.
Check that there isn't still a "Remove after washing" sticker over the buzzer.
HTH David
The speaker of my PanelDue (i7) has a single hole in its center ... The protective plastic is no longer in place. And as I said in a previous comment, when I browse the PanelDue menu, the sound remains correct (volume level setting 5) but is not extraordinary either ... After looking for long hours, I find an improvement with G4 S1 M300 P950 S6400 but however not enough if one is in another room of the house when the printing is finished.
@rudy2a said in M300 Sound is almost inaudible ?:
I don't think it's really realistic to expect to hear it in another part of the house anyway. It's never going to be that loud. The high pitched beeps are attenuated quite strongly.
You're right ... it's an image to say that if I'm in another room of the house, I do not hear it. Simply, for me, the purpose of a beep at the end of printing is to warn us of the end of an impression if we are busy with another activity (3 or 4 meters of the machine for example) and not to stay nose in front of the machine, do we agree or not? If I have to stay with the machine to watch, what is the end of cycle beep for?
@rudy2a
I know this is an old thread but I've just installed a PanelDue 7i and am having the same problem of (almost) inaudible Pieso speaker.Has there been any progress in this area?
It would be really nice to be able to play various tones to signal events.Thanks
@brs Could you capture video or audio recording of what yours sounds like? The speaker isn't exactly loud, but it should be very audible in the the same room. Also, what M300 commands are you sending? Some frequency ranges are louder than others.
Here is the sound test code I'm now using. Definitely tone specific. But still not near as loud as I hoped. Higher tones are not my strong suit due to age related hearing loss.
M291 P"2 KHZ" R"Test Tones" T1.9 S0 M300 S2000 P2000 G4 P2000 M291 P"3 KHZ" R"Test Tones" T1.9 S0 M300 S3000 P2000 G4 P2000 M291 P"4 KHZ" R"Test Tones" T1.9 S0 M300 S4000 P2000 G4 P2000 M291 P"5 KHZ" R"Test Tones" T1.9 S0 M300 S5000 P2000 G4 P2000 M291 P"6 KHZ" R"Test Tones" T1.9 S0 M300 S6000 P2000 G4 P2000
Here is a link to the video (114mb) with sound. The fan you can hear in the background is almost inaudible but comes through clearly on the video as do the tones which I can't hardly hear in real life. The phone camera is about a 12" from the paneldue.
https://www.dropbox.com/s/sgzrxcri6q6tpju/20220617_130957.mp4?dl=0
Yah. With the paneldue the M300 commands produce a tone that's only audible if you're standing right next to the printer. Which makes it kinda pointless.
There is plenty of space in the PanelDue mount enclosure on my printer. I'm wondering if anyone has tried to remove the piezo speaker and wire in a small amp with a real speaker.
The goal here is to be alerted from across the shop or in the next room of major printer events.
I'm in the process of wiring in a row of DotStars which should be able to at least give me a visual clue (flashing lights or something).
@brs the main function of the piezo in PanelDue is to provide feedback when you touch an active field on the panel. As you have observed, it isn't very loud.
It's driven in differential mode by 3.3V signals. There is a 470 ohm series resistor. You could try reducing the value of that resistor but I suspect you still wouldn't get the volume you want.
If you want to hook up an external amplifier, pick off the signal from just one of the pins of the piezo along with ground.
