Z-probe triggers way above table during HOME ALL
That all looks right to me.
Do you have anything weird in config-overide.g?
That all looks fine as well.
Firmware version?
Double check wiring? Bad crimp? Clean the sensor with some isopropyl?
@phaedrux do you have a link to the latest update?
@phaedrux thank you, I will update today and check for hardware issues
@billsrf said in Z-probe triggers way above table during HOME ALL:
@dc42 went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
Perhaps you have a bad crimp connection in the sensor cable, so that one of the 3 wires disconnects at certain XY positions?
