Z-probe triggers way above table during HOME ALL
after home.all, I can push HOME.Z and it moves to the bed and sets the correct nozzle height
@phaedrux i have the offset Z trigger height set to zero for testing. What should the X-Y settings be for the G31? isnt it center of my build plate?
@billsrf The X and Y values for G31 should be the distance of the probe from the nozzle. Just as the Z value is the distance from the probe to the nozzle tip in Z.
If the probe is to the left, the value will be -x.
If the probe is to the right, the value will be +x.
If the probe is to the front, the value will be -y.
If the probe is to the back, the value will be +y. -
my BED.G looks like it is missing a lot of information now for some reason. 0_1555961191732_bed.g
It looks like your bed.g is currently setup to just do a mesh grid compensation run.
@phaedrux ok, i will measure the offset and change that in the G31 in config.g
If I am not using a bed compensation. Why would that be making my trigger so high off my build surface? It moves down about 20 mm then triggers during home.all. But, if i do a home.z afterwards it moves to the correct trigger height and it is ready to go
Have you gone through these steps?
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
yes 9 times. I will change the offsets and then go through the probe set up again
@dc42 went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
@phaedrux went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
Tried running a G29 and this is what I am getting back now. I have never had this kind of issue with my duet3d before. its triggering during moves.
Is the sensor on the IR probe dirty or damaged at all?
@phaedrux No, i have even swapped it out with a new probe and it does the same thing!! I am baffled!!! to say the least. As you can see it won't run a G29 anymore either
@phaedrux I have another Duet3d wifi board, I am going to swap it out in the morning and reload my firmware and see if that does it
Can you post your config.g as it is now?
That all looks right to me.
Do you have anything weird in config-overide.g?
