BLV mgn Cube - 3D printer Project
@blv Looks like a great printer!
One question though: in the BOM you list high temp magnets. How and where do you attach them?
Great looking project! The finishes are looking amazing on the sample parts.
One question, I looked at your S3D profile, you aren't using relative extrusion? Any reason why you don't use it?
very nice. I wish your design had been done before i build my corexy.
how does it compare to your blv AM8?
have you tried the robotdigg mgn rails? i had some problems with my rails from CNA Mechanical Parts Store
@wilriker said in BLV mgn Cube - 3D printer Project:
@wilriker Hi, you have two options:
- to stick a flexible sheet of adhesive magnet (i don't like this option, since the flex magnet sheet is not flat at all areas)
- The best option to my opinion: stick high temp 12 magnets with 3M adhesive (in the BOM i gave a link for the magnets and sticker in one place) in on top of them the Bed insulation.
I also made an image that will explain it:
@timcurtis67 said in BLV mgn Cube - 3D printer Project:
@timcurtis67
I got to point that it the print quality was good for me, However i guess that when
i will have some free time - changes can be made@veti said in BLV mgn Cube - 3D printer Project:
@Veti
Honestly, both are good although the moving bed was a bit less optimal for bigger prints.
Also, the robotdigg are excellent as long as the measurements are the same as MGN12H -
@blv said in BLV mgn Cube - 3D printer Project:
2. The best option to my opinion: stick high temp 12 magnets with 3M adhesive (in the BOM i gave a link for the magnets and sticker in one place) in on top of them the Bed insulation.
If that image had been there yesterday already I must have missed it.
On my setup I am also thinking about going for magnet build surface and also dislike the magnetic sheets. Since I do have a separate aluminium plate (5mm) and silicone heater pad, sticking the magnets even onto the silicone heater pad will leave me with barely any forces on the top side. I can stick them all around the silicone heater pad but that would only provide me magnetic forces on the edges of the spring steel sheet.
Only way around that is to sink the magnets into the aluminium plate either from top or the bottom but I am not really looking forward to do this.
My god!
The timing on this, I've been thinking about going to a XYCore style printer to eliminate the massive moving bed back and forth!And it's from the same guy as the AM8.. Couldn't be any better!
Awesome work you've done there
I like the way that it's open at the front, like the E3D tool changer.
@Blv I am glad you have posted this way of fitting a magnetic sheet. I have been considering this exact method recently while searching Aliexpress and its good to see someone else doing this method to confirm that it's not a silly idea
@Blv I'm impressed with your documentation, Great Job.
I'm looking to build a corexy in the next few months and stumbled across this on thingiverse and am interested. I wanted to point out for the magnetic heated bed, Aliexpress has a 300 watt 300x300 heated bed with the magnets already attached and it comes with a spring steel top. I have one on order to try on my Taz 6 printer and figured you may be interested.
Here's the link.
Great respect to your work!
Your doku is really good and you have really put in a lot of time - no children and no woman at home?
I like your belt guide and the belt tensioner!
Which sense has the deflection at the corners?Your doku is really good and you have really put in a lot of time - no children and no woman at home
which sense has the deflection at the corners?PS: Today I have ordered the hardened replacement balls for the MGN12 - suuuuper tip!
@thwe said in BLV mgn Cube - 3D printer Project:
Your doku is really good and you have really put in a lot of time - no children and no woman at homeThank you, you will be surprise to know that i do have wife and small children..
Making it took tons of time, stress and angry wife.. but it was worth it -
Queria modificar alguns arquivos, vocΓͺ consegue disponibilizar os arquivos 3D dos itens ?? o que vocΓͺ disponibilizou nΓ£o consigo ter acesso as pecas.
@gleison said in BLV mgn Cube - 3D printer Project:
Translate: I wanted to modify some files, can you make the 3D files available for the items ?? What you have made available can not access the parts.
Do you mean CAD files?
@phaedrux isso mesmo, os arquivos CAD de todos os itens para que eu possa editar.
Ave you looked at the thingiverse link? It looks like a lot of the step files are there..
@phaedrux estΓ£o apenas os arquivos STL e esse tipo de arquivo eu nΓ£o consigo alterar.
@phaedrux
98% of the project step files can be found there.
