Yet another cast aluminum plate topic...
Not to take over the thread, but has anyone used 3M 468MP to attach a mirror to an aluminum bed?
I hate hate hate hate hate clips or the likes, they get in the way and reduce build area.
@wyvern said in Yet another cast aluminum plate topic...:
I restrain my glass plate in 3 directions from the side. I still need to modify (improve) it since the heat cycling loosens the screws over time, but the aluminum is flat enough that after polishing it, if I lift only the glass, the aluminum sticks to it for a few seconds and is lifted up as well.
I usually have to slide the glass plate off the aluminum plate to separate them.
I was using the binder clips before but found that it warped the glass slightly because they clamped at the very edge of the glass. -
@jrjones88
You have a nice plate then, mine, while it works surprisingly with no compensation will visibly warp if one adjustment knob is too tight, it's too thin IMHO to use alone.I'm testing out corner clamps, they work, but they reduce build area by 10mm and seem to interfere with the bed adjustment (cocked to one side)- but prints look better.
I will leave 1 inch corner uncovered from adhesive, that way I can get a scraper under and peel- its .1mm thick.
I use Swiss Clips, they're unobtrusive but allow me to remove the glass relatively easily. I'll see how they work with the 3/8" APT5 and 1/4" glass.
That's why I use build plates that are a little larger than the area reachable by the nozzle. I don't see any point in using a glass plate on top of the aluminium if you can't remove it very easily.
Another reason to use an oversized built plate is that the edges will inevitably be a little cooler than the rest.
@dc42 OT but do you think this paint would work with the mini differential IR sensor?
Rust-Oleum Specialty 12 oz. High Heat Satin Bar-B-Que Black Spray Paint
https://www.homedepot.com/p/Rust-Oleum-Specialty-12-oz-High-Heat-Satin-Bar-B-Que-Black-Spray-Paint-7778830/202315061 -
Here's what a 750W Keenovo heater does on a 300x300x8mm MIC6 plate set to 100C:
Notice that the ears of the plate read much cooler than the rest of the plate. It looks like temperature drops off rapidly as you move away from the outline of the heater, so using an oversized plate may not provide any more printable area.
@mrehorstdmd it'll be interesting to see how it turns out for me. I've ordered a 120v 1000w 450×450mm Keenovo, due to the holiday in China I likely won't receive it until the end of February. I'm going to try adapting the mount design you used. Where did you get the Teflon blocks from?
@dc42 The conundrum is the nozzle and cradle assembly sit very low, so I can't clip to the rear of the plate at all as it juts out 3 inches from the bed, the build plate sits very close to the the tray- so much so that the clip interferes with the adjustment of the bed, I could install larger springs however.
I only print on build mats, these require a scraper and mild rapping on the handle, this moves the plate around.
Clipping onto the this thin bed causes the mirror to warp.
I would buy a CNC'd bed, but the one available requires an expensive silicone heating mat $140 I can't justify just yet.
Glass has a lot less expansion when heated and mirrors are usually very flat, I don't use a probe, so if the build plate is warped i'm SOL.
With A/C heating mats, is there not a way to use the duet signal to turn on/off control the heat? everything I have seen uses a dedicated controller.
I will never go back to a rolled plate for any size above 250. The cast aluminum does not warp as much as the rolled/extruded ones so they are necessary for any bigger area
Here is what I now have on the V-King CoreXY
Video -
@tletourneau said in Yet another cast aluminum plate topic...:
https://www.homedepot.com/p/Rust-Oleum-Specialty-12-oz-High-Heat-Satin-Bar-B-Que-Black-Spray-Paint-7778830/202315061Probably, although matt black would be better than satin.
@tletourneau I get Teflon from a local supplier, Midland Plastics. They have a commercial showroom where they sell cut-offs of all sorts of plastics and composites. When I go there, about twice each year, I always check for small Teflon scraps and buy them even if I don't have an immediate use for them. Teflon is very easy to machine and its slipperiness and moderately high temperature tolerance make it useful for all sorts of things.
Someone at the Makerspace works at a company that makes industrial electrical controls and they use a lot of Torlon. He brings bags full of cut-off pieces to the Makerspace for people to use. It's very difficult to machine, but it's very strong and withstands high temperatures.
@mrehorstdmd thanks! Did you tap where the bolts go into the side of the plate? Also, what size bolts did you use for the bed spring retention? If I missed it in the blog post I apologize. The plate I ordered is 3/8" thick.
@tletourneau If you're referring to the screws that hold the plate-end of the hold-down springs, yes, they are tapped. I used #6-32 screws. The bolts that hold the other end of the hold down springs go into the axial holes in the bed support. They are 5/16-18 tapped holes and screws.
In SoM, which I recently upgraded to a line powered heater and kinematic mount, instead of drilling into the edge of the bed plate (only 1/4" thick), I made the ears wider and drilled through the plate and tapped the holes. Like this:
@mrehorstdmd thanks again! I'm going to try a slightly modified version of the kinematic mount. I'm going to have it mounted to 2020 with the ball screws and springs across the front and back of the plate. We'll see how it goes, the plate shipped out today so I should have it tomorrow or Monday. The heater shipped from China today as well so that should be here in a week or two (I hope).
So I adhered the glass to my heated bed, got it level-ish, looked closely and the bed is warped pretty badly.
713 maker just ran out of stock on the milled bed, go figure.
So the question is, should I go SSR or with the Keenevo controller? I found a 300W silicone mat (I don't need crazy heat-up times)
@wyvern what is the keenovo controller?
@phaedrux Keenovo offers an external temperature controller.
It's a little self-contained heat controller and timer, no wiring to the Duet at all.
The problem I see with it is the inability to set the bed temp with G-code, the upside is the reduction in wiring and since it's remote, no chance of it damaging the due... unless it decides to start on fire.
@wyvern I went with a SSR, I prefer to let the Duet control the temperature. It is really useful for prints like some of the ABS where I drop the bed temp after a few layers.
