Solved Need advice on new heated bed aluminium plate
2mm glass is the absolute minimum. I used it for a while and I had no problems. Except when a spool fell on it.
I know some of you are aware of these plates...
Has anyone here used one of these plates before?
Im thinking about thinking of building a new printer and I think Im going to go corexy. I'd really like to use a bed like that so as not to deal with all the.. pardon my italian... bed adhesivion fuckery
I am dealing with the same issue.
So where can one get a precision ground aluminum plate made to size?
If your in the US, try these guys...
https://www.midweststeelsupply.com/store/castaluminumplateatp5
@ricky_grade10 said in Need advice on new heated bed aluminium plate:
Thank you VERY much. I've looked many times but never found them.
@fcwilt Both my deltas, Orangie and Mr. Pink, use 1/4 inch tooling plate from them and both plates arrived quickly and have been awesome
You name your printers? Funny.
@fcwilt said in Need advice on new heated bed aluminium plate:
So do I, Carl Sagan and Richard Feynman, doesn't everyone?
Yep! "BFD" = Big Fast Delta. And if you think that's what the F really stands for...
You know that cast aluminum tooling plate can be cut with a hack saw, jig saw, table saw, or miter saw. You don't have to order a specific size...
I had a bitch of a time originally finding midwest too. I have a 300 x 300 on my coreXY. The Alcoa MIC6 seems to be a lot more expensive than the Vista ATP5 plate that they carry. And for this application who cares about Alcoa.
If you have the ability to cut it yourself, S & S Machine sells surplus tooling plate aluminum discs in various sizes. I ordered two a few years ago, and currently use one on my delta.
Jumping in on this. I'm thinking about moving to a cast aluminium plate, I'm stuck on what thickness to get. The plate would be 500x500mm (19.6875"2 square) and the options seem to be 1/4", 5/16", or 3/8". In that size the 1/4" and 3/8" are the same price and the 5/16" is $10 more. I'm just not sure which way to go. Any advice would be truly appreciated. My machine is a CoreXY with dual Z axis using single start T8 leadscrews that have a 2mm lead. On the plus side I live about 90 minutes away from Midwest Metal Supply.
Thanks,
Tom
Anyone experience with them?
@tletourneau When it comes to thickness, you're balancing rigidity against heat-up time. You can get an idea of heat-up time from this site: https://jscalc.io/calc/uS8JYjYISgIvzJ1x 1/4" plate may be a little thin for that size depending on how thin you want to print your first layer, or whether or not you're going to use mesh compensation.
A 500x500 plate will expand about 1mm when heated to 100C. Make sure the mounting system can deal with that- the mount is usually not heated, so the screw locations don't move by 1 mm. I have used a kinematic mount on 2 printers (so far) and it works well.
@mrehorstdmd thanks for the reply, I'll keep the mount in mind. I guess I have to decide between the 5/16 (12.22lbs, 7.9375mm) or 3/8" (14Lbs, 9.525mm). It's a fairly large build area (at least in my mind) and I'm concerned about rigidity. I have a 3mm heat bed now and it is not the most rigid thing in the universe.
I also can't seem to get a good automatic bed level (my dual Z's are independently driven) or a good mesh. I'm using dc42's mini differential IR sensor but I can start another thread for that. I do have a 1/4" glass top on the bed.
I am actually really aware of exactly this shop and plate. I was considering to buy one of these but: the price compared to an uncoated plate is insane. 220mm² uncoated (different shop, same plate) cost 15 €. The coated one you linked 55 €. That's 40 € for PEI on both(!) sides - who needs PEI on the side where the heater is attached anyway?
Only real advantage of this plate would be to have the holes for mounting screws already drilled as compared to the other one and I don't have neither a drill press nor a milling machine, so drilling exact holes with only a cordless drill is a bit daunting.
Does anyone think the additional weight of going with a 14lb (3/8") plate over a 12.2lb (5/16") plate would have a detrimental effect on the Z axis?
@wilriker said in Need advice on new heated bed aluminium plate:
Lots of people use these plates on top of the heated alu bed (with clamps). It is nice to have a plate that you can turn over to choose between a glossy or a matte finish.
@tletourneau said in Need advice on new heated bed aluminium plate:
Probably not.
BTW I've replied to the other thread that you've started with more or less the same topic.
